Page 2 of 2
Re: octane plugin don't work
Posted: Thu Nov 26, 2015 1:48 pm
by supermac
ok.. sorry.. i don't understand very well..
i installed the redistributable package,
but i don't change houdini.env
i can't open houdini.env
i must change something in houdini.env or not?
i use windows 10.. it's a problem?
Posted: Thu Nov 26, 2015 1:53 pm
by juanjgon
In Windows 10 all should work fine. Don't you have a houdini.env file in your Documents/Houdini15.0 folder, where you have put the plugin folders?
With the plugin folders in the $HOME directory, you don't need to touch the houdini.env file, but it must be there, in the Documents/Houdini15.0 directory.
I must leave now for one hour, perhaps later we could chat by skype if you can't fix the problem.
Posted: Thu Nov 26, 2015 1:56 pm
by supermac
a screen capture
it's right?
Posted: Thu Nov 26, 2015 2:54 pm
by supermac
Don't work..
i placed all together with houdini.env, in the same file.
Posted: Thu Nov 26, 2015 3:18 pm
by juanjgon
Ok. I was wrong, my mistake, sorry.
Even if you copy all the plugin folders in the Houdini $HOME directory, you must edit the houdini.env file and add the PATH line:
PATH = "C:/Users/Orel/Documents/houdini15.0/bin;$PATH"
Please, add this line to the houdini.env file and try again.
Posted: Thu Nov 26, 2015 3:28 pm
by supermac
ok thank you.. but a question..
how i edit houdini.env?
Posted: Thu Nov 26, 2015 3:31 pm
by juanjgon
It is text file, you can edit it with the Notepad without problems.
Posted: Thu Nov 26, 2015 6:02 pm
by supermac
OK coolll..
it's perfect...
Thank you very much.
Now i can try.
Thank you for your super job.
See you
Best regards
Posted: Thu Nov 26, 2015 6:10 pm
by juanjgon
Great! ... the problem is that in Linux you don't need to set this PATH variable, and I had forgotten that in Windows you must always set it, even for a bin folder in the $HOME directory.
