Re: RealFlow Motion Blur
Posted: Mon Nov 16, 2015 7:52 pm
That's not a matter to get or can't get the speed vectors without having this functionality in our plugin.
aoktar wrote:That's not a matter to get or can't get the speed vectors without having this functionality in our plugin.
Of course not. I think you're assuming that things are automatically implemented by a single command. Absolutely not. Lot of calculations and preparation is done while converting scenes. That's not possible without generating and registering the speed vectors for generated octane scenes. As i try to explain that was not easy to read vector speeds of geometries. Even C4D sdk had not efficient methods as i can know. So you should wait for a solution in plugin or try to use in standalone.momade wrote:las thought for today.
should not the c4d-plugin be able to produce the same output than standalone?
here i downloaded the alembic file, that produces perfect motion blur in standalone.
viewtopic.php?f=33&t=44704&p=229784#p229971
aoktar wrote:Of course not. I think you're assuming that things are automatically implemented by a single command. Absolutely not. Lot of calculations and preparation is done while converting scenes. That's not possible without generating and registering the speed vectors for generated octane scenes. As i try to explain that was not easy to read vector speeds of geometries. Even C4D sdk had not efficient methods as i can know. So you should wait for a solution in plugin or try to use in standalone.momade wrote:las thought for today.
aoktar wrote:Great. I'm investigating how can we read vertex velocity values from vpost data. I'll give you info.
that´s good news! usability of other vertex channels (like age, speed etc.) would be interesting too.aoktar wrote:Great. I'm investigating how can we read vertex velocity values from vpost data. I'll give you info.
