Page 2 of 16
Re: Version 2.16.0
Posted: Fri Jan 02, 2015 5:01 pm
by schodt
OK so I just tried to save out some materials from standalone (v 2.15) again, and save them in the localDB. This results in that c4d closes whenever I click on the "localdb" tab in the liveDB window. I've attached the livedb folder from my prefs folder here.
Re: Version 2.16.0
Posted: Fri Jan 02, 2015 5:18 pm
by albehany
hi aoktar thank you for the hard work
i just install the new 2.16 and when i try make new material i get this message
Re: Version 2.16.0
Posted: Fri Jan 02, 2015 5:28 pm
by aoktar
schodt wrote:OK so I just tried to save out some materials from standalone (v 2.15) again, and save them in the localDB. This results in that c4d closes whenever I click on the "localdb" tab in the liveDB window. I've attached the livedb folder from my prefs folder here.
try with 2.16.
Re: Version 2.16.0
Posted: Fri Jan 02, 2015 5:44 pm
by aoktar
albehany wrote:hi aoktar thank you for the hard work
Thanks. Can you see any files in "res" folder in c4doctane? It says that cannot open or found *.res files
Re: Version 2.16.0
Posted: Fri Jan 02, 2015 6:24 pm
by schodt
try with 2.16.
Just installed 2.16, erased liveDB folder, saved the materials via. octane standalone 2.16 - still having the same problem.
Re: Version 2.16.0
Posted: Fri Jan 02, 2015 6:26 pm
by aoktar
schodt wrote:
try with 2.16.
I cannot reproduce the problem here. Anyone has similar problem? Also i'm uploading a new version with some minor fixes on "localdb". May helps to you.
Re: Version 2.16.0
Posted: Fri Jan 02, 2015 6:30 pm
by schodt
Also, ORBX import isn't working here either :shock: I've attached the ORBX file I'm trying to open, to this post..
Re: Version 2.16.0
Posted: Fri Jan 02, 2015 6:36 pm
by aoktar
schodt wrote:Also, ORBX import isn't working here either :shock: I've attached the ORBX file I'm trying to open, to this post..
what are you trying? Getting the geometry? It's not possible. Only material import should work but i haven't checked it since ages.
Re: Version 2.16.0
Posted: Fri Jan 02, 2015 6:37 pm
by schodt
I'm just trying to get the materials :) I actually tried saving the materials via. Standalone first by saving it in the localDB(which didn't work), so I tried importing the ORBX file, but it isn't working either.
EDIT: OK I finally got it to work by grouping the material along with its nodes in Octane Standalone, right-clicking and saving the material it self as an ORBX file. Saving it to the localDB still makes C4D crash.
Re: Version 2.16.0
Posted: Fri Jan 02, 2015 6:42 pm
by aoktar
schodt wrote:I'm just trying to get the materials :) I actually tried saving the materials via. Standalone first by saving it in the localDB(which didn't work), so I tried importing the ORBX file, but it isn't working either.
do this way. Select material and save as orbx. Then import and voila...
