Re: OctaneRender® for Maya® 2.11.1 - 5.6 Linux [CURRENT]
Posted: Mon Nov 10, 2014 4:58 am
Are you sure some other renderer does not use the CUDA resources? VRay RT for example?..
Community Forums for OTOY Customers
https://render.otoy.com/forum/
lspci -v | NVIDIA
VGA compatible controller: NVIDIA Corporation GK110GL [Quadro K6000] (rev a1) (prog-if 00 [VGA controller])
Subsystem: NVIDIA Corporation Device 1036
Flags: bus master, fast devsel, latency 0, IRQ 118
Memory at fa000000 (32-bit, non-prefetchable) [size=16M]
Memory at e0000000 (64-bit, prefetchable) [size=256M]
Memory at f0000000 (64-bit, prefetchable) [size=32M]
I/O ports at d000 [size=128]
[virtual] Expansion ROM at fb000000 [disabled] [size=512K]
Capabilities: <access denied>
Kernel driver in use: nvidiaCode: Select all
dpkg -l | grep nvidia
ii nvidia-340 amd64 NVIDIA binary driver - version 340.46
ii nvidia-340-dev amd64 NVIDIA binary Xorg driver development files
ii nvidia-340-uvm amd64 NVIDIA Unified Memory kernel module
ii nvidia-cuda-dev amd64 NVIDIA CUDA development files
ii nvidia-cuda-doc all NVIDIA CUDA and OpenCL documentation
ii nvidia-cuda-gdb amd64 NVIDIA CUDA GDB
ii nvidia-cuda-toolkit amd64 NVIDIA CUDA toolkit
ii nvidia-opencl-icd-340 amd64 NVIDIA OpenCL ICD
ii nvidia-prime amd64 Tools to enable NVIDIA's Prime
ii nvidia-profiler amd64 NVIDIA Profiler for CUDA and OpenCL
ii nvidia-settings amd64 Tool for configuring the NVIDIA graphics driver
ii nvidia-visual-profiler
