Page 2 of 2
				Re: Problem with Displacement
				Posted: Tue Aug 26, 2014 9:00 pm
				by aoktar
				yes, you can see it in this video:
[vimeo]http://www.vimeo.com/94517190[/vimeo]
				Posted: Wed Aug 27, 2014 7:51 am
				by prodviz
				Very nice.
Gonna ask if we can have the same in Maya.
cheers.
				Posted: Wed Aug 27, 2014 3:12 pm
				by Rudi
				aoktar wrote:your are still expecting magic via a low res image. Check my picture, displacement source image which is produced by a gradient
Therefore, each grayscale image has stairs?
Unless one uses the shaders of C4D.
Can you increase then maybe the resolution to 16k and/or 32 k, so that the stairs are really tiny?
				Posted: Wed Aug 27, 2014 3:34 pm
				by aoktar
				Rudi wrote:aoktar wrote:your are still expecting magic via a low res image. Check my picture, displacement source image which is produced by a gradient
Rudi,
Don't wanna understand? It's user problem not related with plugin.
It's not issue of resolution. You should use high res. images as at least of displacement resolution. And 32bit images are better.
				Posted: Sun Aug 31, 2014 12:16 pm
				by centropolis
				Hello,
Now work correctly.
octane ver 2.05 and octanec4d ver 2.05.
Thank you for the support.
centropolis
				Posted: Sun Aug 31, 2014 3:27 pm
				by Rudi
				aoktar wrote:Rudi wrote:aoktar wrote:your are still expecting magic via a low res image. Check my picture, displacement source image which is produced by a gradient
Rudi,
I believe, now I have understood it.
However, one cannot refine then the Displacement resolution even further, with 16384, instead of 8192 now.
I mean the result.
For what, otherwise, one has then the choice of 256, 512, 1024, 2048, 4096 and 8192.
				Posted: Sun Aug 31, 2014 3:46 pm
				by inlifethrill
				You seem to be missing basic understanding of the process. Please refer to this document and, once again, read all the answeres you got so far.
http://en.wikipedia.org/wiki/Displacement_mapping
If this does not help - nobody here can.
Best,
Dobs
				Posted: Sun Aug 31, 2014 4:29 pm
				by Rudi
				Hi Achmed,
I believe, we speak sometimes again each other past.
Therefore, here sometimes the pictures what I generally mean.
And why I ask whether it does not go still higher than 8192x8192.
			-  256x256
			-  512x512
			-  1024x1024
			-  2048x2048
			-  4096x4096
			-  8192x8192
			-  15000x1800
With 8192x8192 many your details which are not to be seen with 4094x496 are shown.
Did it should not with 16384x16384 even more give to see?
Greetings Rudi
				Posted: Sun Aug 31, 2014 4:59 pm
				by aoktar
				8192 is limit of Octane. you should live with it
				Posted: Sun Aug 31, 2014 5:29 pm
				by Rudi
				aoktar wrote:8192 is limit of Octane. you should live with it
Thus done theme.
Thanks for your help and patience. Even if we talk at cross-purposes from time to time sometimes .
