Page 2 of 2
Re: Octane Sketchup Exporter - Full 1022-08
Posted: Wed Sep 29, 2010 9:22 pm
by TIG
Tim
Re: second reply - the other model seems to not have the problems with scene/images but is failing to do the CD and so it's not finding the cmd file[ which is actually working] - I'll double-check the code...
You say it works if you type the text into a cmd window ?
Thanks for the useful feedback so far.
Posted: Wed Sep 29, 2010 10:34 pm
by timbarnes
TIG wrote:Tim
I see from the error reports athe there are two separate errors;
One is to do with the number of scenes in an animation [#1884] - perhaps you only have one ?
Try adding one or two more scenes and see it that error goes
I can see a fix for this and it's in hand...
The other [#2752] is to do with having an image in the model -it should be trapped and export properly - I can also see a fix for that too...
Try exploding the image into a face or hiding it/putting it on an off layer - it should then work...
So it's nothing to do with your setup more glitches/typos in my code that combine when you have a certain scene count and images in the model
When these are fixed I'll post an update shortly... Look out foe something new soonest...
Hi TIG:
Thanks for the quick response. I don't know what you mean by "scenes in an animation". I'm not doing animations, just single frame renders of a single model at a time.
I will investigate the image issue and report back.
tim
Posted: Wed Sep 29, 2010 10:56 pm
by timbarnes
TIG wrote:Tim
I opened a fresh cmd window and typed in the cd and the start commands: they both worked fine, and Octane opened.
But I don't really know what's going on. I just ran SketchUp on a different file, and the plugin correctly output the data and opened it in Octane. So it seems to be intermittent.
tim
Posted: Wed Sep 29, 2010 11:01 pm
by MartyMart
Hi
Following is taken from Ruby Console :-
"Error: #<Errno::ENOENT: No such file or directory - >
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/Octane/Octane_1022.rb:78:in `mkdir'
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/Octane/Octane_1022.rb:78:in `dirMkdir'
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/Octane/Octane_1022.rb:2878:in `make_texture_folder'
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/Octane/Octane_1022.rb:2884:in `export_textures'
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/Octane/Octane_1022.rb:2663:in `export_start'
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/Octane/Octane_1022.rb:2645:in `do_export'
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/Octane/Octane_1022.rb:2593:in `run_exporter'
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/Octane/Octane_1022.rb:1404:in `export'
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/Octane/Octane_1022.rb:1455:in `render'
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/Octane/Octane_1022.rb:316:in `initialize'
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/Octane/Octane_1022.rb:1884:in `call'
Cheers
Posted: Wed Sep 29, 2010 11:02 pm
by TIG
The animation part of the dialog adds available scenes to the lists for available 'start' and 'end' scenes.
But it should do that only if you have at least two scenes available - since doing an animation of one scene is daft!
There was a glitch in the code - if you had just one scene it added that as the available 'start' and then failed because it couldn't find a scene to put into the 'end'... NOW I've recoded it so that you need at least two scenes and the 'start' is 'nil' and the end is 'nil' otherwise...
So it was failing because you had just the one scene - with no scenes, or two or more it would be fine - it's now fixed anyway...
I've fixed the typo glitch with the image transformation so it should now work...
I don't know why the ;cd; isn't working on your setup it's fine on my PC [Vista 32bit] and many others - you have Win7 64bit ???
You can do the cd manually in a cmd terminal window ?
I've tweaked the code slightly - added a \ to the end of the directory path - still works in Vista 32bit and it might just sort out your problem... Please test the new version asap an report back - I'll post the update shortly...
Posted: Wed Sep 29, 2010 11:09 pm
by TIG
MartyMart wrote:Hi
Cheers
MM
Do you have any special/accented-characters in the file-path?
It seems to be failing to make the texture-folder as it can't find the project-folder to put it into.
If you make the texture folder manually do you get erro messages - the folder-name is XXX_Textures where XXX is the project-name, it goes in the project-folder...
It should ever get to the point of failing as it should check that the parent-folder exists first ???
I'm about to issue an update too - please try that and report...
Posted: Wed Sep 29, 2010 11:57 pm
by TIG
Version 1033-09 is now available and addresses many of the concerns raised in this thread...
