Page 2 of 2
Re: Activation issue
Posted: Wed Jan 16, 2013 3:33 am
by badmilk69
Why not uninstall Poser then install everything again? classic solution.
Posted: Wed Jan 16, 2013 3:36 am
by face_off
It's a fresh install of Poser - and from the Poser forums it looks like a common error related potentially to Adobe Air and the firewall. I'm still not sure why this is effecting activation, but we are working through it at the moment.
Posted: Wed Jan 16, 2013 11:26 am
by face_off
In case anyone else has this issue - it has been tracked down to an issue with the 32 bit installer for the plugin. I have now rectified this issue and Piet is testing it. The Poser "Fault Detected!" is a separate issue, related to Flash or Adobe Air which Piet will need to resolve too
Posted: Wed Jan 16, 2013 1:38 pm
by pfrancke
Plugin Activation issue has been resolved by new version Paul created.
The Poser Library issue seems unrelated to the activation issue -- Actually I think I was activated and software just didn't recognize it for some reason. (based on current behavior you only need to activate once, not every time you upgrade).
I have a support email from Poser that I need to walk through to fix "library" issue - if I can get that working (so that I have confidence in Poser), then I'll do the upgrade to the Poser 64 bit software (which seems silly to me is not a feature in Poser 9).
I wish to share that Paul worked this issue with me very aggressively. We exchanged emails and I sent log files etc and he stuck to the problem and was outstanding in his help with this and I thank him very much in his support to get me straightened out!!!!
Posted: Tue Jan 22, 2013 10:43 pm
by face_off
I just updated Adobe Air, and am now getting Piet's Poser Library issue
Posted: Tue Jan 22, 2013 11:03 pm
by wimvdb
Just wondering - is it not a firewall issue. The Air library is a separate program, it might have a different signature now which is not recognized by the firewall and may need to be allowed again
Posted: Wed Jan 23, 2013 10:28 pm
by pfrancke
About the Poser problem, I followed their procedures, but even though I was able to go to their page and see the XML code (meaning it was working), I followed the below procedure and then I was OK. So for me, it was how my network/LAN works.
Open Intenet Explorer > choose Tools > Internet Options > click the CONNECTIONS tab > click LAN SETTINGS > Uncheck the "Automatically detect settings" box > click OK > then click OK again > Then retry loading the link above.
