Re: Maya Plugin for 2013.5?
Posted: Thu Nov 29, 2012 3:39 pm
phaskins
Ooops!
It's the first time when Autodesk broke this formal registry path system... There was always "...\2011\...", "...\2012\..." paths...
Thank you for report. It will be fixed in installator in the next version (it is almost ready, I will release it in a few hours).
As a "quick-fix", if you want to get it installed right now, you can just add the path "HKLM\SOFTWARE\Wow6432Node\Autodesk\Maya\2013\Setup\InstallPath" and create there the string value key "MAYA_INSTALL_LOCATION" holding the path to your Maya installation (just copy it from the same key from 2013.5 path). After it you may run the installator and all will be OK.
Ooops!
