Page 2 of 2
Re: Background environment not appearing
Posted: Wed Oct 03, 2012 10:01 pm
by justix
emihich wrote:Oh my Gosh, I Thougth only dropping the HDR texture in the Max environment slot would do it.Thank you Buggy.
Why is this not covered in the documentation ? and which kind of material shall I use ?there is no texture environment material , but difuse , Glossy, specular etc...
Also I can't drop an Octane material in the max environment slot , it won't accept.
Please explain your workflow.
I think I know what you mean I've applied an Octane Image texture bitmap, not a material , on the 3dsmax environment slot ... and worked.
How EXACTLY should we do this? the Environment slot will make the background behave differently from having a viewport background image that I'm now testing for some camera matching test..I'll attach a screenshot..
Posted: Wed Oct 03, 2012 10:06 pm
by Karba
Octane doesn't allow you to use background image by the same way as screen mode in 3dsmax.
Posted: Thu Oct 04, 2012 6:50 am
by justix
Ouch :shock: is this going to be fixed in a future release? Or is there a different way to obtain same results with Octane? I presume a sort of matte/shadow material composition and post production is in need....
Posted: Wed Oct 17, 2012 11:42 pm
by emihich
:roll: I forgot to say that I have applied an environment texture from Octane maps, and dropped in Max
environment slot,Then I copied it into the material editor (drag&drop) and applied an Octane image
as a texture for the environment .
I've chosen an HDR file and tweaked it, from the power , rotation and even gamma options in the
Texrture environment ,and image rollouts.
Basically you control Octane environment ,as an instance in the material editor.
