Per-vertex color data from splines
Forums: Per-vertex color data from splines
Moderator: aoktar
Postby speltrong » Mon Jun 14, 2021 3:49 pm
speltrong Mon Jun 14, 2021 3:49 pm
Hi
Is it possible to get per-vertex color data from splines yet? This would particularly be helpful in x-particles where trail splines can change color based on certain criteria that would be very difficult to match with w-coordinate
-s
speltrong
Re: Per-vertex color data from splines
Postby aoktar » Mon Jun 14, 2021 6:12 pm
aoktar Mon Jun 14, 2021 6:12 pm
There's not any attribute that contains color for vertexes of splines. xpTrail is a special object and latest build has support to read this data. See my example for that.
Postby speltrong » Mon Jun 14, 2021 7:47 pm
speltrong Mon Jun 14, 2021 7:47 pm
Thanks @aoktar!
Good to know that that's data that's specific to the xpTrails object and not the spline itself
-s
speltrong
Postby aoktar » Mon Jun 14, 2021 7:51 pm
aoktar Mon Jun 14, 2021 7:51 pm
speltrong wrote:Thanks @aoktar!
-s
Yes, do you know another method to paint splines?
Postby speltrong » Mon Jun 14, 2021 9:13 pm
speltrong Mon Jun 14, 2021 9:13 pm
You can change the display color of the spline. Redshift and Arnold can pull that data and you can feed it into the different channels.
speltrong
Postby aoktar » Mon Jun 14, 2021 9:35 pm
aoktar Mon Jun 14, 2021 9:35 pm
speltrong wrote:You can change the display color of the spline. Redshift and Arnold can pull that data and you can feed it into the different channels.
It's not for vertex painting, and using many hair nodes are bottleneck for performance.
Postby speltrong » Mon Jun 14, 2021 10:19 pm
speltrong Mon Jun 14, 2021 10:19 pm
got it - thanks!
speltrong
Postby Ofcourse » Thu Feb 22, 2024 4:01 pm
Ofcourse Thu Feb 22, 2024 4:01 pm
Hi @aoctar please are you aware of bug while I use a deformer with xpTrail object which has color stored please? With deformer the Octane does not render stored colors
Ofcourse
Postby aoktar » Thu Feb 22, 2024 5:19 pm
aoktar Thu Feb 22, 2024 5:19 pm
Ofcourse wrote:Hi @aoctar please are you aware of bug while I use a deformer with xpTrail object which has color stored please? With deformer the Octane does not render stored colors
Yes, check my past answers.
Return to Maxon Cinema 4D
Users browsing this forum: No registered users and 22 guests
Sun May 12, 2024 5:26 pm [ UTC ]
