Now... IS there any help here on this forum? Or not?
Forums: Now... IS there any help here on this forum? Or not?
Moderator: BK
Postby MyRho » Tue Dec 05, 2023 9:35 am
MyRho Tue Dec 05, 2023 9:35 am
I've posted some quesions about the plugin 2023.1.1.306 in DAZ Studio 4.22.0.1.
1. It's not possible to download any materials from the Live DB in DAZ studio. The texture-slot is empty and the material is rendered in black.
2. I can't acess my materials-preset anymore. There not a single material in it and I've had some dozens... Is there a path to the presets and how can I get them back?
Thank you.
M.
Intel Core i7 3960X, X79A-GD65 (8D) (MS-7760), 32 GB DDR3-SDRAM G.Skill,
Asus GeForce GTX 3060 12GB, Windows 10 Pro 64-Bit.
Nihil sum sine sole.
MyRho
Re: Now... IS there any help here on this forum? Or not?
Postby frankmci » Tue Dec 05, 2023 5:28 pm
frankmci Tue Dec 05, 2023 5:28 pm
Instead of being snarky about the forum, you could write directly to [email protected].
Technical Director - C4D, Maya, AE, - Washington DC
frankmci
Postby Hun73rdk_1 » Wed Dec 06, 2023 8:42 pm
Hun73rdk_1 Wed Dec 06, 2023 8:42 pm
Most of this forum is user driven also there is a bug with the live database but the database is useless all shaders are outdated you get better results making your own
Join the Octane Daz Fan server for people that uses daz and octane https://discord.gg/wDzwC8tqAK
Hun73rdk_1
Postby mlru » Fri Dec 08, 2023 5:11 am
mlru Fri Dec 08, 2023 5:11 am
MyRho wrote:I've posted some quesions about the plugin 2023.1.1.306 in DAZ Studio 4.22.0.1.
Thank you.
M.
Had the same problem. The only solution right now is going back to version v2022.1.211. It's a bug in newer versions I reported a while ago.
Maybe it'll be fixed if ever the development of OcDS continues...
Win11/64Bit | GTX 4090 24GB | NVidia Driver 546.29 | Octane 4.05 | DAZ Studio 4.21
mlru
Postby Hun73rdk_1 » Sun Dec 10, 2023 9:56 pm
Hun73rdk_1 Sun Dec 10, 2023 9:56 pm
Thank you.
M.
You do know every shader in the livedb is outdated and are really bad now compared to the new version of octane people should learn to make there own will help them in the long run.
Hun73rdk_1
Postby mlru » Tue Dec 12, 2023 2:01 am
mlru Tue Dec 12, 2023 2:01 am
Thank you.
M.
How does this help the OP's problem?
mlru
Postby Hun73rdk_1 » Tue Dec 12, 2023 3:51 am
Hun73rdk_1 Tue Dec 12, 2023 3:51 am
Close down daz go into C:/users/*username*/OctaneRender/Data/ and delete OctaneRender_livedb2.oczdb go back into daz and in octane window press update under live db and turn off auto update.
And try and see if its updates and download the db again
Hun73rdk_1
Postby MyRho » Tue Dec 12, 2023 9:32 am
MyRho Tue Dec 12, 2023 9:32 am
Hun73rdk_1 wrote:Close down daz go into C:/users/*username*/OctaneRender/Data/ and delete OctaneRender_livedb2.oczdb go back into daz and in octane window press update under live db and turn off auto update.
Thank you - I did that before.
The LiveDB was updated but that didn't change anything:
- can't use LiveDB because of missing texture files.
- can't use my own materials - they seem to be gone.
- after a while in DAZ it's not possible to enter any data in the octane window. I can't change a name of a material or change any value manually.
And - at least - I'm very disappointed about the fact, there's still no support for strand-based hair after all these months.
M.
MyRho
Postby elsksa » Tue Dec 12, 2023 12:08 pm
elsksa Tue Dec 12, 2023 12:08 pm
mlru wrote:How does this help the OP's problem?
It's a valid suggestion and one step forward greater satisfactory results.
elsksa
Postby Hun73rdk_1 » Tue Dec 12, 2023 11:38 pm
Hun73rdk_1 Tue Dec 12, 2023 11:38 pm
M.
Like i said the livedb is outdated and is missing a ton of textures its old has probably not been updated for many years
also if your OctaneRender_presets.oczdb has been delete all your own shaders are gone take backup sometimes of the file there also should be a backup file in same folder.
Also a good idea of having scenes with the same shaders or save as shaders in daz will also preserve the octane shaders.
Also the problem with daz and octane have never had sometimes daz UI bugs out and you cant write numbers in either daz or octane and that is a daz problem.
Hun73rdk_1
Next
Return to DAZ Studio
Tue May 14, 2024 5:55 am [ UTC ]
