OctaneRender 2022 for Modo [OBSOLETE]
Forums: OctaneRender 2022 for Modo [OBSOLETE]
Re: OctaneRender 2022 for Modo [TEST and STABLE]
Postby face_off » Fri Jan 27, 2023 3:55 am
face_off Fri Jan 27, 2023 3:55 am
On a Linux, I am not getting options for texture repeating. Modo 16.0v3 and latest Octane. Tried reseting preferences too.
It is working fine for me. Did you delete all your Modo*.CFG files?
Paul, I am aware that you probably do not support 16.1 Beta yet, but just as a heads up. Octane crashes Modo16.1 Beta on startup, on Linux.
I tried downloading the Linux beta, but the Foundry website seems to be glitched for it (download is OK for Windows and macOS). I have pinged Foundry about it. Once I get a resolution I will take a closer look.
Postby SreckoM » Sat Jan 28, 2023 10:12 am
SreckoM Sat Jan 28, 2023 10:12 am
Paul it was something with my Modo installation or OS. Reinstall everything and Octane works with 16.1 Beta.
Issue with no Border Modes exposed is still present though, for both beta and 16.0v3 version, with Octane .189. It works with .187 version of Octane.
SreckoM
Postby face_off » Sun Jan 29, 2023 2:18 am
face_off Sun Jan 29, 2023 2:18 am
I think Modo is finding another CFG file containing the old Border Mode property. Either there are two OctaneRenderForModo_Forms.CFG files, or the the old Border Mode property has been saved to the Modo->System->User MODO16.0.CFG file. Also, try adding an Image node to the Schematic, and check the Channels tab - are the Border Mode (U) and (V) channels present?
Postby SreckoM » Sun Jan 29, 2023 1:17 pm
SreckoM Sun Jan 29, 2023 1:17 pm
Yes, they are present. That is how I managed to tweak value. Will double check configs, but I did test this on fresh Modo and Octane installs.
SreckoM
Postby face_off » Sun Jan 29, 2023 11:45 pm
face_off Sun Jan 29, 2023 11:45 pm
SreckoM wrote:Yes, they are present. That is how I managed to tweak value. Will double check configs, but I did test this on fresh Modo and Octane installs.
Hi - I think the installer has packaged the wrong CFG file. Can you try this version please? https://render.otoy.com/customerdownloads/plugins/4f/f3/35/b5/OctaneRender_for_Modo15-16_2022_1_0_189_Linux_STUDIO.run
Postby face_off » Sun Jan 29, 2023 11:52 pm
face_off Sun Jan 29, 2023 11:52 pm
I just tried with Build 119 (2023.01.25) and Octane started rendering fine, but then everything locked up when I clicked the Stop button.
EDIT: Just tried again and it was working fine. So unsure if it was a "one-off" issue or not.
Postby SreckoM » Mon Jan 30, 2023 9:48 pm
SreckoM Mon Jan 30, 2023 9:48 pm
It works now, thanks Paul!
SreckoM
Postby face_off » Tue Jan 31, 2023 4:35 am
face_off Tue Jan 31, 2023 4:35 am
SreckoM wrote:It works now, thanks Paul!
Thanks. The link at the top of this thread has been updated to link to this new installer build.
Postby SreckoM » Mon Feb 06, 2023 11:00 am
SreckoM Mon Feb 06, 2023 11:00 am
Paul is it possible to implement option, maybe in Preferences, when creating Override to always use Universal? I am rarely using anything else nowadays.
SreckoM
Postby face_off » Tue Feb 07, 2023 5:43 am
face_off Tue Feb 07, 2023 5:43 am
SreckoM wrote:Paul is it possible to implement option, maybe in Preferences, when creating Override to always use Universal? I am rarely using anything else nowadays.
I did a lot of work on this last year (ie. conversion of Principled to Universal and a bunch of other enhancements), but shelved it prior to the final release of 2022.1. I plan on getting back to it in the next month or so, so I think you will see implemented.
PreviousNext
Return to Foundry Modo
Fri May 17, 2024 10:13 pm [ UTC ]
