Why the Octane Renderer overexposed my image either in...
Forums: Why the Octane Renderer overexposed my image either in...
Area for student license holders to post questions and discuss octane.
Postby Ofcourse » Tue Nov 08, 2022 12:46 pm
Ofcourse Tue Nov 08, 2022 12:46 pm
Why the Octane Renderer overexposed my image either in the Render Queue and also in Render Picture Viewer? The final imafe file on my drive is fine but the preview of the image being rendered is overbrighted...
I do remember that this started to happen at some point with some version of Octane when it rendered the same output two times... the one overbrighted and the Main right... Please help me why is it happens.
Ofcourse
Re: Why the Octane Renderer overexposed my image either in...
Postby aoktar » Tue Nov 08, 2022 1:46 pm
aoktar Tue Nov 08, 2022 1:46 pm
Ofcourse wrote:Why the Octane Renderer overexposed my image either in the Render Queue and also in Render Picture Viewer? The final imafe file on my drive is fine but the preview of the image being rendered is overbrighted...
It's because of color management of Picture Viewer. We cannot correctly communicate/manage it. Just disable to see expected results.
Postby Ofcourse » Tue Nov 08, 2022 2:42 pm
Ofcourse Tue Nov 08, 2022 2:42 pm
What do you mean by "Just disable to..."? What I should disable?
Ofcourse
Postby aoktar » Tue Nov 08, 2022 3:12 pm
aoktar Tue Nov 08, 2022 3:12 pm
Ofcourse wrote:What do you mean by "Just disable to..."? What I should disable?
I wrote that:
"color management of Picture Viewer"
Postby elsksa » Tue Nov 08, 2022 3:49 pm
elsksa Tue Nov 08, 2022 3:49 pm
It might be the option that has to be disabled. I've shared a guide and a Cinema 4D specific screenshot here: https://www.elsksa.me/scientia/cgi-offline-rendering/octane-render-color-management
If it is what I think it is, it has nothing to do with exposure, but instead, transfer function.
elsksa
Postby Ofcourse » Fri Nov 11, 2022 5:06 pm
Ofcourse Fri Nov 11, 2022 5:06 pm
My another question is why octane keeping to rendering double time the each frame of my sequences? So after the job is done there are always two times the same sequence, but one is overexposed and another one is fine (_MAIN) in the name.
I read in your documentation that I should not use the C4D save options and leave it disabled and set this up in the octane render settings, but this does not help me out.
Ofcourse
Postby elsksa » Fri Nov 11, 2022 10:02 pm
elsksa Fri Nov 11, 2022 10:02 pm
Ofcourse wrote:(...) but one is overexposed and another one is fine (_MAIN) in the name.
Over-exposed ≠ "double EOTF"
Double EOTF aka going from Linear-sRGB to "conformed" (ready to display and for the web) sRGB applied twice.
Did you disable the Cinema 4D "Enable Color Profile" as shown on the page I've linked?
Did you follow the guidelines from that same link?
If unsure, it will be necessary to share all relevant settings: Octane Camera Imager + settings window ("preferences") + Cinema 4D color management related settings.
elsksa
Postby Ofcourse » Mon Nov 14, 2022 1:09 pm
Ofcourse Mon Nov 14, 2022 1:09 pm
Thank you for your willing to help here, I will respond later on today
Ofcourse
Postby elsksa » Mon Nov 14, 2022 2:42 pm
elsksa Mon Nov 14, 2022 2:42 pm
You are welcome. No rush, no pressure.
elsksa
Return to General Discussion
Tue May 21, 2024 11:12 am [ UTC ]
