Cinema4D version 2021.1.5-(R4) (Stable 2021) 28.06.2022
Forums: Cinema4D version 2021.1.5-(R4) (Stable 2021) 28.06.2022
Moderator: aoktar
Re: Cinema4D version 2021.1.5-(R4) (Stable 2021) 28.06.2022
Postby desire » Sun Aug 07, 2022 6:13 pm
desire Sun Aug 07, 2022 6:13 pm
With last version R4 I get almost no automatic material updates in a LiveViewer
Please see screenshot
I've changed color from blue to white, and material type from Glossy to Diffuse, but no update in a liveviewer. Other nodes like projection or transform with no updates too.
Updates come after pressing Send Scene button only.
Thank you
desire
Postby aoktar » Mon Aug 08, 2022 6:41 am
aoktar Mon Aug 08, 2022 6:41 am
desire wrote:With last version R4 I get almost no automatic material updates in a LiveViewer
Thank you
What happens if you change some parameters after that?
Postby desire » Mon Aug 08, 2022 7:35 pm
desire Mon Aug 08, 2022 7:35 pm
aoktar wrote:What happens if you change some parameters after that?
Thank you for answer.
After pressing Send Scene button nothing changes. The same not-updating material.
But I figured up some details with this issue:
- material that has update trouble is assigned to an object with ObjectTag (I'll put a screenshot with settings at the end of the message).
- updates come with Camera object changing point of view (cam movement). But works with Camera that was in the scene earlier only. Didn't understand. Creating new Camera or copying original and changing point of view through them get no update result.
- in a Live Viewer if make right click over that material (assigned to obj+objtag) - menu shows like there is no material assigned - offers to create new material and not offer to select/copy/paste (screenshot below)
- other objects of a scene that have ObjectTag - have no problems with updates.
Solution that I found - re-assign to object. Remove+assign.
Thank you
ObjTag settings
right click option
desire
Postby aoktar » Mon Aug 08, 2022 8:43 pm
aoktar Mon Aug 08, 2022 8:43 pm
Desire,
That's not a common issue. Even not an issue that's seen unless something wrong or unexpected at setup or settings. Is it happening with every scene? Even with a new scene? Please delete Oct. dat from preferences directory and run C4D.
Postby desire » Tue Aug 09, 2022 10:25 am
desire Tue Aug 09, 2022 10:25 am
aoktar wrote:Desire,
You're right it's not a common issue. Hard to find more conditions for the occurrence of the issue at the moment.
Do you mean .dat file on a path C4Ddir\plugins\c4doctane\Libs300?
desire
Postby aoktar » Tue Aug 09, 2022 4:31 pm
aoktar Tue Aug 09, 2022 4:31 pm
preferences dir from C4D/Settings
Postby desire » Wed Aug 10, 2022 6:19 pm
desire Wed Aug 10, 2022 6:19 pm
aoktar wrote:preferences dir from C4D/Settings
Found it! Thank you
desire
Postby Kalua » Tue Aug 23, 2022 11:02 pm
Kalua Tue Aug 23, 2022 11:02 pm
Is there anything I should know when rendering with Cinema Picture viewer?
Some instanced objects (not render instances) will render properly on "Liveview window" and will render all white shaded on Picture viewer. Why could it be?
PS.: now I made these instanced objects editable, they render properly... go figure.
C4D 25.117 Octane 2022.1.2 R4, <<2 X 3090 + NVlink>>, Windows 10, X399, AMD TR 1950X, 128 GB RAM, NVIDIA SD 536.67
Kalua
Previous
Return to Releases
Users browsing this forum: No registered users and 11 guests
Fri May 10, 2024 8:08 am [ UTC ]
