Autodesk AutoCAD (Integrated Plugin developed by OTOY, maintained by Paul Kinnane)
Postby Leandersson » Wed Jun 01, 2022 1:51 am
Leandersson Wed Jun 01, 2022 1:51 am
I'm having issues with Octane X PR14 on my Macbook M1 Max.
I installed a separate version of Cinema 4D R25 and run it through Rosetta and getting this error when I try to start the render view:
Started logging on 31.05.22 21:44:11
Octane X Studio PR14 (10000308)
Compute error 2097152:825:
compute device 0: Linking 00696900aaaadec4 shader failed
device 0: failed to initialize render thread 0x7fb8cafa2400
The log says this:
Creating zip file:/Users/johan/Library/Preferences/Maxon/Maxon Cinema 4D R25_EBA43BEE/_bugreports/octane/bugreport_20220531_214403.zip
Adding file:/Users/johan/Library/Preferences/Maxon/Maxon Cinema 4D R25_EBA43BEE/c4doctanelog.txt
Loaded Octane DLL:Octane X Studio PR14  version:10000308  SDK:PR14
Octane X for Cinema 4D PR14  built for:250   C4D vers:25120
C4D:25120  comp:[V2T4MRQWX6-JLeandersson]  OS:[OS X 64 BIT] macOS: Version 12.3 (Build 21E5196i)  versType:10
CPU:[GenuineIntel, stepping 0, model 12, instruction family 6]  speed:2.4 GHz  numOfCpu:10
Plugins:[addons advanced_render alembic aligntools archigrass assetbrowser bitmapfilter bpexchange browser bugslife_client c4d_emulation c4d_viewport_render c4doctane-R25 ca ca2 cadexchange clothilde collada14 collada15 colorchoosergui compositing cyctypes deltamush deployment dropzone dwg dwgobjects dynamics exchanges expressiontag fbx gltf gorillacam goz hair hdrilink i_skp interop interop_forger io_forger io_obj lightkit3 lighttypes metrics mkmodeler mocca model mograph motioncam motiontracker nbo nbp newman nodeeditor objects onlineupdater physx_hybrid pluslibrary projectassetinspector python redshift redshift4c4d relaxuv scenemanager2 sculpt sculptbrushes shader signal sketch sky sla socialframe spacemouse substance teamrender thinking_particles tool_system_hybrid tpoperators usd uvviewport volumes xpressocore xtensions ]
Loaded 89 osl scripts from dir:/Users/johan/Dropbox (Personal)/C4D/C4D_OctaneX_Studio_PR14/res/osl_scripts
Deleting texCache folder... /Users/johan/Library/OctaneRender/cache/texCache
VRAM used/free/max:0Kb/64Gb/64Gb  Out-of-core used:0Kb  RAM used:30.986Gb total:64Gb  OpenGL free/total:0/0
FumeFx library initialisation error!
Multi-threaded material conversion, thread count=8
Export materials time= 0.075 ms
Collect objects time= 0.021 ms
Mesh creation time = 0.208 ms.
Api update time: 0.043 ms.
<<< Render failure detected!!! >>>
Please check render statistics to solve the problem.
 MB:0/0  ST/MOV:0/0  Nodes:10  Tris:0  DispTris:0  Hairs:0  Meshes:0
 Textures Grey8/16:0/0  Rgb32/64:0/0
>> ProcessUpdate(flags=CMO cAsyn=1 dDelay=1
>> ProcessUpdate end res:0
File not found:/Users/johan/Library/Preferences/Maxon/Maxon Cinema 4D R25_EBA43BEE/updates-ox.txt
ResetAndInit 0
ResetAndInit [OK]
Export materials time= 0.054 ms
Collect objects time= 0.013 ms
Mesh creation time = 0.204 ms.
Api update time: 0.034 ms.
Any ideas what might be wrong?
Leandersson
Postby altestudio » Mon Jun 06, 2022 1:51 pm
altestudio Mon Jun 06, 2022 1:51 pm
Is colour management feature going to be implemented soon so that ACES can be used in Octane X on macbook for cinema4d? I'm thrilled octane is working on my M1 macbook but without ACES it's basically useless to me :(
altestudio
Postby atracksler » Tue Jun 07, 2022 12:31 am
atracksler Tue Jun 07, 2022 12:31 am
Hi octane team, any updates on the silicon build? I know you’re working hard, but it’s been almost 6 months into my year subscription without being able to use octane in Cinema. Was hoping to get some insight.
atracksler
Postby bepeg4d » Tue Jun 07, 2022 8:25 am
bepeg4d Tue Jun 07, 2022 8:25 am
@Leandersson: the log shows that also RedShift is installed, but it is incompatible with the Rosetta mode:
So you should need to have two versions of C4D installed, one for native plugins like RedShift, and another one in Rosetta mode for c4doctaneX and any other plugin not in native mode for M1 chip.
@altestudio and atracksler: we need to wait for the upcoming 2022.1-XB2 SDK, the core devs are working on it, to have the first M1 c4doctane plugin, also supporting ACES/OCIO.
ciao,
Beppe
Postby Leandersson » Tue Jun 07, 2022 1:12 pm
Leandersson Tue Jun 07, 2022 1:12 pm
bepeg4d wrote:@Leandersson: the log shows that also RedShift is installed, but it is incompatible with the Rosetta mode:
Thank you! Unfortunately, this did not help. I removed Redshift for the Rosetta version of C4D and the result is still the same.
It doesn't seem to be an issue with other plugins but rather something with the GPU since I still get this error message.
device 0: failed to initialize render thread 0x7f7d92816160
Leandersson
Postby sebbans » Thu Jun 09, 2022 2:13 pm
sebbans Thu Jun 09, 2022 2:13 pm
Just want to say, I'm super thankful OctaneX works on my Silicon Mac in C4D r25, fantastic to use. And I'm really looking forward to the first native plugin for S26 so that I can run everything natively without having to switch between versions.
sebbans
Postby tolitoli » Thu Jun 09, 2022 2:15 pm
tolitoli Thu Jun 09, 2022 2:15 pm
it seems my subscription will end but I will not try M1 c4doctane plugin
I have been waiting since October 2021
tolitoli
Postby bepeg4d » Fri Jun 10, 2022 7:21 am
bepeg4d Fri Jun 10, 2022 7:21 am
@Leandersson: please write to help at otoy dot com, asking for Beppe, I need to investigate more deeply.
@sebbans: Thanks for your positive feedback!!!
@tolitoli: for licenses issues, please write to help at otoy dot com too, thanks.
ciao,
Beppe
Postby altestudio » Mon Jun 13, 2022 6:25 pm
altestudio Mon Jun 13, 2022 6:25 pm
ciao,
Beppe
Thanks Beppe. Do you have a rough timeline for when this is likely to be released? Are there usually announcements when there are new releases? Octane is working better on my mac than I expected and aces will be the cherry on top!
altestudio
Postby bepeg4d » Tue Jun 14, 2022 9:43 am
bepeg4d Tue Jun 14, 2022 9:43 am
@Leandersson: sorry, didn't notice at first time, but c4doctane plugin is installed in a custom wrong path, and even worse, in Dropbox :roll:
Please go to c4d menu Edit/Preferences/Plugins, and remove the octane folder from the list:
The installation paths for Mac is:
  • HD\Applications\Maxon Cinema 4D R2X\plugins\C4D-OctaneX-PR14 (You have to create the plugins folder in lower case!)
After installation, please open c4d, then go to c4d menu Extensions/Console, (Shift+F10), and copy paste the default console output in your answer, thanks.
Please, also share a screenshot like this one, that shows both the c4doctane directory opened, and the entire installation path, thanks:
ciao,
Beppe
PreviousNext
Return to Autodesk AutoCAD
Users browsing this forum: No registered users and 18 guests
Sun Apr 28, 2024 5:48 pm [ UTC ]
