VDB not rendering
Forums: VDB not rendering
VDB not rendering
Postby Carnera » Tue May 05, 2020 10:23 pm
Carnera Tue May 05, 2020 10:23 pm
Hi guys
I have a very simple setup ...
vdb pointing to single vdb file
volume object
cube
cube and vdb volume shows up in Modo renderer
Octane just shows the cube any ideas why?
I tried Modo 13 and Modo 14.
Octane v. 2020.1.0.161
Andras
http://www.checkpointvfx.com
Carnera
Re: VDB not rendering
Postby Carnera » Tue May 05, 2020 10:31 pm
Carnera Tue May 05, 2020 10:31 pm
Never mind
I tried it in Modo 14. same setup, same vdb and now it renders.
Strange.
Andras
Carnera
Postby Carnera » Tue May 05, 2020 10:38 pm
Carnera Tue May 05, 2020 10:38 pm
Now I closed down Modo.
Opened it up again. Remade the same setup and Ooctane does NOT show the volume (Modo renderer shows the vdb).
I give up. Very flaky.
Andras
Carnera
Postby face_off » Wed May 06, 2020 4:05 am
face_off Wed May 06, 2020 4:05 am
I am aware of issues with VDB items in Modo13 and earlier, which Modo14 fixes. In general, I think you are better off putting the .VDB files into an ORBX proxy, as this will give you much better control of how the VDB file renders. Please see https://render.otoy.com/forum/viewtopic.php?f=34&t=73939 for details.
Postby Carnera » Sat May 09, 2020 2:25 am
Carnera Sat May 09, 2020 2:25 am
Hi Paul
I got it working in Modo 14.
Modo 14 was not reading the vdb sequence ( using Modo's native VBD reader item)
So I went with the Octane Standalone app approach you mentioned ( viewtopic.php?f=34&t=73939 ).
But I had a couple of problems. ( maybe its my lack of knowledge in Octane ;))
- Did not know how to add the Volume Material. ( I think it would be good if you could post a screenshot of that graph too). In the end I added a volume material (see attached image)
- I was not sure where and how to save the graph or the Orbx. I tried right-mouse save on the Geometry Node directly...which was wrong and gave errors in Modo. So I decided to save the OrbX in the File / Save as Package ....again something that is not clear in your tutorial....again, could be also my lack of Octane knowledge.
- Did not know how to alter / modify the Volume material inside of Modo. But I found out that the "empty" Item that loads the OrbX proxy has an option "Edit Proxy File" ...which opens the Standalone Graph and that's where I was able to change look (density etc) of the Volume. (please correct me if thats not the right approach)
There is one more thing. The render stopped at a specific frame. Did not know why. But it looks like "Auto Save" in Modo (my scene is super heavy..1.7 BG modo file) which lead to that Octane stopped rendering.
Maybe its a bug?
Anyway..it works now. And rendering is super fast. :))
Andras
Carnera
Postby face_off » Sun May 10, 2020 11:27 am
face_off Sun May 10, 2020 11:27 am
That is the correct way to do it. I will amend the forum post to reflect this.
Yes, File->Save as Package to the correct way to do this. I will amend the forum post to reflect this.
Yes, again, you have it correct, and I will amend the forum post accordingly.
Maybe its a bug?
I have never seen this happen (but your assessment seems feasible). Perhaps turn off auto-save in Modo prior to rendering large files such as this.
Postby Carnera » Thu May 14, 2020 4:41 pm
Carnera Thu May 14, 2020 4:41 pm
Thank you Paul for confirming. ;)
Andras
Carnera
Postby leblanc980 » Mon Jun 13, 2022 3:16 pm
leblanc980 Mon Jun 13, 2022 3:16 pm
Hello,
.VDB's disappear when placed onto a placement node or group node through Octane Standalone when imported into MODO as a proxy.
Connecting a single .VDB directly onto the Render Target appears though.
Windows 10. Octane 2021.1.5.186 & 2021.1.3.184.
Any thoughts appreciated.
leblanc980
Postby face_off » Wed Jun 15, 2022 1:42 am
face_off Wed Jun 15, 2022 1:42 am
leblanc980 wrote:Hello,
This has been answered in the other thread.
Return to Foundry Modo
Users browsing this forum: No registered users and 51 guests
Sat Apr 27, 2024 4:02 pm [ UTC ]
