Cinema4D version 2022.1-XB1-(R3) (Experimental) 02.06.2022
Forums: Cinema4D version 2022.1-XB1-(R3) (Experimental) 02.06.2022
Moderator: aoktar
Re: Cinema4D version 2022.1-XB1-(R2) (Experimental) 26.05.2022
Postby aoktar » Thu May 26, 2022 6:48 pm
aoktar Thu May 26, 2022 6:48 pm
Postby Meet » Thu May 26, 2022 11:10 pm
Meet Thu May 26, 2022 11:10 pm
Thank you, color VDBs work great!
Thin film in standard surface material still doesn't work
Meet
Postby aoktar » Fri May 27, 2022 12:38 pm
aoktar Fri May 27, 2022 12:38 pm
Have you checked in Standalone? It's not working in there too.
Postby Meet » Fri May 27, 2022 1:39 pm
Meet Fri May 27, 2022 1:39 pm
aoktar wrote:Have you checked in Standalone? It's not working in there too.
Yes, I had checked and asked, it works in standalone
Metalness is 1
Ryzen 9 5900x | 64GB RAM | 1x RTX 3090
Blender | C4D | Standalone
Win 10
Meet
Postby aoktar » Fri May 27, 2022 2:11 pm
aoktar Fri May 27, 2022 2:11 pm
Metalness is 1
It's working if you connect a float texture. Assumed that's not working because used rgb color.
Postby SSmolak » Fri May 27, 2022 9:33 pm
SSmolak Fri May 27, 2022 9:33 pm
Undo doesn't work if node is still selected after changing parameter while using embedded GUI
SSmolak
Postby jiabangshou104 » Sat May 28, 2022 1:25 am
jiabangshou104 Sat May 28, 2022 1:25 am
"Photon Tracing "often gives memory RAM errors when noise reduction is enabled.
Octane Render AOV group cannot be saved.
"Photon tracing"在开启降噪时经常出现内存RAM报错。
使用Octane Render AOV group时无法保存。
jiabangshou104
Postby SSmolak » Sat May 28, 2022 2:24 pm
SSmolak Sat May 28, 2022 2:24 pm
Changing Layered Material type to different one like Diffuse doesn't work. Only way is to create new material from scratch.
SSmolak
Postby aoktar » Sat May 28, 2022 7:56 pm
aoktar Sat May 28, 2022 7:56 pm
SSmolak wrote:Changing Layered Material type to different one like Diffuse doesn't work. Only way is to create new material from scratch.
The attachment layered.jpg is no longer available
Not sure what are you showing and how you can see this menu command. It's not appearing on sub materials. And deleting/creating is not only way to change the type. See pic.
Postby SSmolak » Sat May 28, 2022 7:59 pm
SSmolak Sat May 28, 2022 7:59 pm
I mean Octane Composite. I thought that this menu is to convert it to something else ( not layered one ). I have old material with which is layered that now can be done using Octane UIniversal but I see that there is no way to simple convert or change it to Universal one.
SSmolak
PreviousNext
Return to Releases
Users browsing this forum: No registered users and 5 guests
Sun Apr 28, 2024 8:36 am [ UTC ]
