The rgb4k_map.ppm and alpha4k_map.ppm
Forums: The rgb4k_map.ppm and alpha4k_map.ppm
Houdini Integrated Plugin
Re: The rgb4k_map.ppm and alpha4k_map.ppm
Postby juanjgon » Wed May 25, 2022 7:52 am
juanjgon Wed May 25, 2022 7:52 am
chocbot wrote:Hi Juanjo,
is there also a workaround available for using point attributes from the packed geo itself? For example I have a color attribute on a tree's leaves and that tree is instanced then. With that texture workaround it's only possible to get the color attribute per instance but not per point attribute of that instance, right?
Cheers
Are you talking about nested instancing? Can you please share an example scene (as simple as possible) with this workflow?
juanjgon
Postby chocbot » Wed May 25, 2022 9:04 am
chocbot Wed May 25, 2022 9:04 am
Hey,
thanks for your response! No, I'm not talking about nested instancing (though.. is this a planned feature? :)
Here's my demo scene:
https://1drv.ms/u/s!AiO-yRNxbYloggPeZ28J4ano0D-M?e=cxfrSt
The most basic thing would be: I have a tree with a Cd-attribute
and then I instance it.
Can I get that color attribute to render?
My case would be then to have a random color per instance, which is working right now through that instanceTexture-workaround but also to use the instance's point colors. If I do the same without packing, I can for example call the point color Cd2 and the one per copy Cd and use both in my shader. This is what I would want but with packing.
Cheers
chocbot
Postby juanjgon » Wed May 25, 2022 9:24 pm
juanjgon Wed May 25, 2022 9:24 pm
Hmm, nope, I think that something like that is not possible right now. We only support one "Cd" attribute in the instances. The plugin supports nested instancing, you can instance an instancer, but I'm not sure if this is going to help with the double Cd attribute.
juanjgon
Postby chocbot » Mon May 30, 2022 7:25 am
chocbot Mon May 30, 2022 7:25 am
Alright, thanks for the info!
chocbot
Postby yazi10412727 » Fri Apr 19, 2024 10:03 am
yazi10412727 Fri Apr 19, 2024 10:03 am
Hello where to download this ppm file
The ppm file is missing in your package, but only the project. I would appreciate it if you could send me a copy. :D :D :D :D :D
yazi10412727
Postby ricky_otoy » Tue Apr 23, 2024 7:42 am
ricky_otoy Tue Apr 23, 2024 7:42 am
yazi10412727 wrote:Hello where to download this ppm file
The ppm file is in the "tex" folder of the plugin. In the newer builds you don't need to use it, you can setup the Texture Instance Color nodes and link it to the Object Properties of Custom Attribute.
ricky_otoy
Previous
Return to Houdini
Users browsing this forum: No registered users and 22 guests
Sun Apr 28, 2024 12:56 am [ UTC ]
