OctaneRender® for 3ds max® v2021.1 - 12.09
Forums: OctaneRender® for 3ds max® v2021.1 - 12.09
Re: OctaneRender® for 3ds max® v2021.1 - 12.09
Postby paride4331 » Thu Jan 13, 2022 11:35 am
paride4331 Thu Jan 13, 2022 11:35 am
mbetke wrote:Yes. I already updated Studio Drivers yesterday to the new 500 series.
Can't tell what causes it.
Hi mbetke,
Studio driver, right?
paride4331
Postby mbetke » Thu Jan 13, 2022 12:30 pm
mbetke Thu Jan 13, 2022 12:30 pm
Yes. Of course. With a clean installation using "Display Driver Uninstaller".
PURE3D Visualisierungen
Sys: Intel Core i9-12900K, 128GB RAM, 2x 4090 RTX, Windows 11 Pro x64, 3ds Max 2024.2
mbetke
Postby richardyarlett » Thu Jan 13, 2022 3:53 pm
richardyarlett Thu Jan 13, 2022 3:53 pm
SOLUTION TO DENOISED BEAUTY PASS
3DSMAX users.. found a bug in the lastest version 2021.1 - 12.09
It seems that unless you add the DENOISED BEAUTY pass added to your RENDER ELEMENTS, it will ignore the beauty pass as the primary output and only output the raw noised pass, EVEN if you have selected that option in the TOOLS > OPTIONS setting.
richardyarlett
Postby paride4331 » Mon Jan 17, 2022 2:00 pm
paride4331 Mon Jan 17, 2022 2:00 pm
richardyarlett wrote:SOLUTION TO DENOISED BEAUTY PASS
viewtopic.php?f=80&t=78980#p408521
paride4331
Postby richardyarlett » Tue Jan 18, 2022 4:37 am
richardyarlett Tue Jan 18, 2022 4:37 am
PARIDE ??? CAN you confirm my findings ?
richardyarlett
NETWORK RENDERING CONFIGURATION BUTTON
Postby richardyarlett » Tue Jan 18, 2022 4:38 am
richardyarlett Tue Jan 18, 2022 4:38 am
The network rendering configuration button does not appear to do anything. It does not work. It creates no new interface or popup.
richardyarlett
Re: NETWORK RENDERING CONFIGURATION BUTTON
Postby paride4331 » Tue Jan 18, 2022 2:33 pm
paride4331 Tue Jan 18, 2022 2:33 pm
richardyarlett wrote:NETWORK RENDERING CONFIGURATION BUTTON
is not that by chance you have installed the Octane Render Studio instead of Octane Enterprise version?
paride4331
Postby samsue » Wed Jan 19, 2022 10:55 am
samsue Wed Jan 19, 2022 10:55 am
oh man... those new tex/mtl nodes! top!
a little strange organized... but it gave a nice UP in the workflow
samsue
Postby Jani » Mon Jan 24, 2022 11:14 am
Jani Mon Jan 24, 2022 11:14 am
I have a forest pack problem after installing this latest version, in that any time I try to run octane with direct mode enabled and a forest pack object present, I get an instant crash.
I've got a link to a video which describes this available here:
https://drive.google.com/file/d/1pt9aXq ... sp=sharing
and an empty max file with the Octane preset helper here:
https://drive.google.com/file/d/1ahBp0h ... sp=sharing
Please try to fix this.
i9 9920X, 64GB, RTX 2080Ti
Ryzen 1800x, 64GB, 2x RTX 3090
Jani
Postby Templas » Mon Jan 24, 2022 7:16 pm
Templas Mon Jan 24, 2022 7:16 pm
Hello, I have an error when rendering a beauty pass in PNG format, just black and white stripes (Alpha enabled), if render in EXR, then everything is fine.
Templas
PreviousNext
Return to Releases
Users browsing this forum: No registered users and 5 guests
Sun Apr 28, 2024 2:49 pm [ UTC ]
