Octane.dll not valid ?
Forums: Octane.dll not valid ?
Houdini Integrated Plugin
Postby Creative_Sheep » Tue Jan 18, 2022 3:28 pm
Creative_Sheep Tue Jan 18, 2022 3:28 pm
I installed the Houdini Plugin version, Octane_2021.1.1.1 each time I start Houdini, I get the error; The Octane.dll file is not valid for this plugin version. Plugin version: 11000014 - Octane.dll version:11000100.
Although I have Octane installer 2021.1.1 ?
Creative_Sheep
Re: Octane.dll not valid ?
Postby juanjgon » Tue Jan 18, 2022 3:40 pm
juanjgon Tue Jan 18, 2022 3:40 pm
Probably you have several versions of the plugin installed in your system at the same time, breaking the installation. Please, double-check that you have only one plugin directory in your system and if you have the right config in your houdini.env or packages file PATH and HOUDINI_PATH variables.
juanjgon
Postby Creative_Sheep » Tue Jan 18, 2022 3:50 pm
Creative_Sheep Tue Jan 18, 2022 3:50 pm
juanjgon wrote:Probably you have several versions of the plugin installed in your system at the same time, breaking the installation. Please, double-check that you have only one plugin directory in your system and if you have the right config in your houdini.env or packages file PATH and HOUDINI_PATH variables.
I have Octane Enterprise 2021.1.1 installed, and a packages file to find the path of Octane, nothing else ?
Creative_Sheep
Postby galleon27 » Tue Jan 18, 2022 4:52 pm
galleon27 Tue Jan 18, 2022 4:52 pm
Go to the plugin directory and check if you have multiple dlls in the dso folder. You should only have one that matches your Houdini version.
Win 10 64bit // GTX 4090 + GTX 3090 // 5900x // 64GB // SideFX Houdini // C4D
galleon27
Postby juanjgon » Tue Jan 18, 2022 6:41 pm
juanjgon Tue Jan 18, 2022 6:41 pm
Yep, you should also check if you have an older Octane version installed in the Houdini $HOME directory.
juanjgon
Postby Creative_Sheep » Wed Jan 19, 2022 2:16 am
Creative_Sheep Wed Jan 19, 2022 2:16 am
There is not multiple DLL in the dso folder related to Octane; as well, I don't have an older version of Houdini installed in the Houdini $HOME directory ?
Creative_Sheep
Postby juanjgon » Wed Jan 19, 2022 9:41 am
juanjgon Wed Jan 19, 2022 9:41 am
The "Plugin version: 11000014 - Octane.dll version:11000100" error means that somehow the plugin version and the Octane.dll that you have installed in your system don't match. The plugin is older than the Octane system files.
You should try to find all these files in your HD to be sure that there are no other versions of Octane installed in your system. Please, delete all the Octane versions that you have in your system, download the plugin and unzip it again to be sure that you have a clean installation.
juanjgon
Postby Creative_Sheep » Thu Jan 20, 2022 2:38 am
Creative_Sheep Thu Jan 20, 2022 2:38 am
My File manager when I first checked; wasn't showing any additional Octane.dll files, then it showed; now everything works beautifully. :D
Creative_Sheep
Return to Houdini
Users browsing this forum: No registered users and 21 guests
Sat Apr 27, 2024 11:23 pm [ UTC ]
