@Stuioyf and others, can you try this build and give some feedback? I'm trying to find whats happening.
viewtopic.php?f=30&t=78774&start=30#p407178
Moderator: aoktar
aoktar wrote:@Stuioyf and others, can you try this build and give some feedback? I'm trying to find whats happening.
aoktar wrote:RegSquires wrote:I can confirm that ORBX export from C4D does create jerky animation. I followed these instructions and the output animation works perfectly. This is a confirmed bug I think and I hope OTOY or Maxon or both can look at the issue because it's a real buzz kill.
https://youtu.be/x7oSjaoanuw
What's your C4d version? And who I am here as for you to investigate the case?
And could everyone who write here their C4D versions?
RegSquires wrote:aoktar wrote:RegSquires wrote:I can confirm that ORBX export from C4D does create jerky animation. I followed these instructions and the output animation works perfectly. This is a confirmed bug I think and I hope OTOY or Maxon or both can look at the issue because it's a real buzz kill.
Hi
I am using C4D R24 because I have not upgraded to Monterey yet and the C4D plug-in is not compatible. Mac is MacBook Pro 15 (2018) running Mac OSX Big Sur 11.6
Plug-in is Studio PR11
oneyedog666 wrote:I seem to be getting pretty good results by rendering out with the viewport closed. I do however get some texture malfunctions where the diffusion is off on a few frames. But at least its not jerking.
aoktar wrote:Test build
There's new option in render settings to export ORBX. DON'T FORGET to disable the image saving in render settings! Use "Ignore rendering" for quick export.
https://render.otoy.com/customerdownloa ... T1-win.rar
Users browsing this forum: No registered users and 26 guests
