Cinema4D version 2021.1-RC2(R3) (Current 2021) 04.10.2021
Forums: Cinema4D version 2021.1-RC2(R3) (Current 2021) 04.10.2021
Moderator: aoktar
Re: Cinema4D version 2021.1 RC2 (Current 2021.1) 17.09.2021
Postby cjadams » Sat Sep 18, 2021 2:06 am
cjadams Sat Sep 18, 2021 2:06 am
somehow in my meanderings doing a DDU and uninstalling and reinstalling
I'm back on the latest driver and everything's happy no idea .....I'm gonna blame Windows weirdness combined with crappy Nvidia drivers and call it a day.
cjadams
Postby BCres » Sat Sep 18, 2021 3:10 pm
BCres Sat Sep 18, 2021 3:10 pm
Can someone tell me how to get a Denoised Beauty pass using the Render AOV Render option? AI denoiser does not seem to be available as an option like it is through the add composite inputs on the AOV groups tab (see pics). And the Save Beauty option always gives a noisy version, even if the option is to use Denoised beauty is checked on the Main page.
This is the problem, if I use the first option, it gives me the Denoised beauty but also adds the Denoised Remainder to the exr and makes each file 5mb bigger than it needs to be. Thanks.
BCres
Postby wrapthereal66 » Sun Sep 19, 2021 5:53 am
wrapthereal66 Sun Sep 19, 2021 5:53 am
damnnn thanks for the aov manager !! :D
wrapthereal66
Postby aoktar » Sun Sep 19, 2021 8:25 pm
aoktar Sun Sep 19, 2021 8:25 pm
BCres wrote:Can someone tell me how to get a Denoised Beauty pass using the Render AOV Render option? AI denoiser does not seem to be available as an option like it is through the add composite inputs on the AOV groups tab (see pics). And the Save Beauty option always gives a noisy version, even if the option is to use Denoised beauty is checked on the Main page.
It's correct to do this what you selected. Be sure denoising activated in camera imager. "AI denoiser" is a typo, "Denoised beauty" is correct word.
Postby BCres » Sun Sep 19, 2021 8:40 pm
BCres Sun Sep 19, 2021 8:40 pm
Thank you, Aoktar. Yes, denoise is checked in the camera imager and I am getting the correct outputs for the cryptomattes and the denoised beauty.
I'm just also getting a "Denoised Remainder" layer as part of the .exr file that I don't need and was wondering if there's a way to get rid of that and just get the Denoised beauty and the two cryptomattes.
Anyhow, it's not a huge deal and I can work with it. Thank you for confirming that I'm approaching it correctly.
BCres
Postby lanklaf » Sun Sep 19, 2021 9:42 pm
lanklaf Sun Sep 19, 2021 9:42 pm
The image appears reddish when using the D65 white light spectrum instead of legacy/flat.
So it should be, or am I doing something wrong?
Scene: Octane standard daylight model is set at 45 degrees + 18% gray material. ODT is set to ACES sRGB.
D65 on the left and legacy/flat on the right.
Setting the white point of the Octane Camera to 6500K helps a little, the reddish tint turns yellow.
Does anyone know why the D65 white light spectrum gives a reddish tint and how to work with D65 properly?
System:
i7 8700K / RTX 2020 / 16GB RAM
lanklaf
Postby wrapthereal66 » Mon Sep 20, 2021 4:16 pm
wrapthereal66 Mon Sep 20, 2021 4:16 pm
background object still make crash octane
wrapthereal66
Postby aoktar » Mon Sep 20, 2021 6:51 pm
aoktar Mon Sep 20, 2021 6:51 pm
wrapthereal66 wrote:background object still make crash octane
Could you please give a better feedback with an example?
Postby momade » Mon Sep 20, 2021 7:51 pm
momade Mon Sep 20, 2021 7:51 pm
Hi everyone.
I was two years off of Octane due to work and happy to be using it again.
I don't seem to be able to find the "out of core memory" check box...
Can someone update me on where to find that?
Best.
Moritz
momade
Postby jayroth2020 » Mon Sep 20, 2021 8:07 pm
jayroth2020 Mon Sep 20, 2021 8:07 pm
Octane Settings > Settings tab > OOC tab.
CaseLabs Mercury S8 / ASUS Z10PE-D8 WS / Crucial 64GB 2133 DDR4 / 2 XEON E5-2687W v3 3.1 GHz / EVGA 1600 P2 / 1 EVGA RTX 3090Ti FTW3 Hybrid / 2 EVGA RTX 2080Ti FTW3 Hybrid/ Cinema 4D
jayroth2020
PreviousNext
Return to Releases
Users browsing this forum: No registered users and 16 guests
Sat Apr 27, 2024 10:30 am [ UTC ]
