Rendering artifacts
Forums: Rendering artifacts
Re: Rendering artifacts
Postby pixym » Tue Jun 29, 2021 2:43 pm
pixym Tue Jun 29, 2021 2:43 pm
Have you tried to change the ray epsilon value ?
Work Station : MB ASUS X299-Pro/SE - Intel i9 7980XE (2,6ghz 18 cores / 36 threads) - 32GB - 2 GTX 1080 TI - Win 10 64
NET RENDER : MB Biostar TB250-BTC Pro - Celeron 2C/2T - Open "Mining" Rig - 2 RTX 2080 TI - Win 7
pixym
Postby tomas.base » Fri Aug 20, 2021 2:13 pm
tomas.base Fri Aug 20, 2021 2:13 pm
I would especially recommend quality geometry / meshflow. Much depends on the triangulation and order of the vertices. If the input geometry has 4 verticles / poly and good meshflow for proper automatic triangulation in the OCTANE core (vertex order), then very small bump and normal values are not a problem (+ higher SUB-DIV level). If the geometry is not good, smoothing will stop working on the reflections.
I attach two identical objects, one is triangulated in LW and the other is not.
After automatic triangulation (see oct pass wirefrane) they look almost the same at first glance, the difference is huge.
In some cases, it is better to do triangulation (if the model is not suitable for SUB-DIV) in LW. Sometimes the automatic triangulation of the Octane core is worse on more complex LOW-poly objects and it is better to triangulate in advance in LW. It's individual. The OCT and LW algorithm is different. And a lot depends on the order of the vertices.
Tomas
IPR
octane wireframe pass
source model
tomas.base
Postby pixym » Fri Aug 20, 2021 2:16 pm
pixym Fri Aug 20, 2021 2:16 pm
Hi, thanks for this information.
pixym
Previous
Return to Lightwave 3D
Users browsing this forum: No registered users and 31 guests
Sat Apr 27, 2024 5:44 am [ UTC ]
