Render target and Octane Environment greyed out?
Forums: Render target and Octane Environment greyed out?
Carrara (Integrated Plugin developed by Sighman)
Postby Jonstark » Tue Jun 29, 2021 11:16 pm
Jonstark Tue Jun 29, 2021 11:16 pm
New question, I found that the place where you can fiddle with the Octane Environment settings and where you can change the render target (the place where you can switch the types of rendering done) which is located in the 'Effects' tab of the carrara Scene when selected from the instances tray, however it's completely greyed-out so although I can see the options there, I can't interact or change anything. What do I need to be doing to enable this so I can make those controls useable, and what am I doing wrong?
Jonstark
Re: Render target and Octane Environment greyed out?
Postby protovu » Tue Jun 29, 2021 11:49 pm
protovu Tue Jun 29, 2021 11:49 pm
Maybe, if you have not already,
Look at the top ribbon for:
Edit>Octane Commands> About/Activate Octane Plugin
About/Activate Octane Plugin should not be greyed out. If it is, you may be able to activate by clicking on it.
protovu
Postby Jonstark » Wed Jun 30, 2021 12:40 am
Jonstark Wed Jun 30, 2021 12:40 am
Well, it is true that the 'Activate' button on the About/Activate window is indeed greyed out, but I think that's just because it's already activated. The Octane render window comes up and renders just fine now, I just can't really change the environment or the render target, which is inside the 'Effects' tab of the Scene itself. Can't figure out how to upload a pic or I would show a screenshot...
Jonstark
Postby protovu » Wed Jun 30, 2021 4:24 pm
protovu Wed Jun 30, 2021 4:24 pm
Here is how mine presents. Maybe refer tech support to this image, and your image of same?
protovu
Postby Jonstark » Wed Jun 30, 2021 11:19 pm
Jonstark Wed Jun 30, 2021 11:19 pm
Oh mine presents the same, I'm not having trouble there. It's in the Scene tab, when I want to (for example) switch the Octane renderer type to PMC from direct, all of that area is greyed out.
Jonstark
Postby Jonstark » Wed Jun 30, 2021 11:22 pm
Jonstark Wed Jun 30, 2021 11:22 pm
Now that I'm learning when I decided to try the latest version of OctaneCarrara that it relies on a different license than my old perpetual license, so I only got it working because I 'rented' a Studio license for a month. Maybe the Studio license has other limitations of what it can do? Or maybe I need the Enterprise license to unlock the Octane environment controls and the Octane render target controls? Perhaps if I downgraded back to the old version that I bought the perpetual licenses for, those functions would then unlock again and not be greyed out? Or maybe I'm just missing something obvious... :)
Jonstark
Postby wendyluvscatz » Sat Jul 01, 2023 2:08 pm
wendyluvscatz Sat Jul 01, 2023 2:08 pm
oh damn, same thing, my harddrive failed so had to get a SSD for my C drive and have Windows 10 reinstalled, grabbed wrong version by looks
why is it even there in my downloads FFS, I reinstalled an earlier one and still cannot, grrr between losing heaps of stuff when my drive died and this, I am just so stressed
Win 10 64-bit CPU Ryzen 3 3600g 32GB RAM graphics RTX2080Ti
wendyluvscatz
Postby wendyluvscatz » Wed Jul 05, 2023 5:30 am
wendyluvscatz Wed Jul 05, 2023 5:30 am
[05:17:21.425] OctaneRender 4.01.1 (4010100)
[05:17:21.425]
[05:17:49.347] ERROR : CUDA error 300 on device 0: device kernel image is invalid
[05:17:49.347] ERROR : -> failed to link file
[05:17:49.347] ERROR : device 0: failed to load OSL shader code:
error : Multiple definition of 'cuSptStatistics' in 'cuda_texturenode', first defined in 'snippets_internal'
[05:17:49.347] ERROR : device 0: failed to compile module 0
[05:17:49.735] Scene contents: 0 primitives, 1 cameras, 1 lights, 0 master objects, 1 master shaders
[05:18:01.095] NVAPI initializing...
[05:18:01.097] NVAPI Version: NVidia Complete Version 1.10
this is my oldest V4 in my library, the scene tab etc is not greyed out but it won't render
and I really cannot use the others without the scene options available for animation
I think it's the end of the line for Octane and me, pity, I used it a lot but not willing to keep tossing money at it, sunk cost fallacy and all :cry:
at least on my machine
may explore online cloud options one day if can do by month basis not a years subscription, my income too low for such luxuries (less than the dole in Australia)
wendyluvscatz
Postby wendyluvscatz » Wed Jul 05, 2023 2:56 pm
wendyluvscatz Wed Jul 05, 2023 2:56 pm
Fixed, removed the Mimic plugin now it works, that gave me trouble with something before, I have the Carrara Beta installed as well and will use it in there instead or 32bit
wendyluvscatz
Return to Carrara
Thu May 09, 2024 8:42 pm [ UTC ]
