Looping waves (water) with noise texture - problem
Forums: Looping waves (water) with noise texture - problem
Postby Whispermode » Wed Jun 02, 2021 11:45 am
Whispermode Wed Jun 02, 2021 11:45 am
Hello!
I'm trying to create a very subtle rippling wave effect on a water surface. And I need it to loop.
I've applied a noise texture with a transform node to the bump channel, and I'm keyframing translation on the 'Y'.
It looks great, but I can't get it to loop.
Am I right in saying that the noise (and other procedural) textures don't actually loop/tile? It looks like they're randomly generated...
If so, how might you guys do what I'm trying to do?
Thanks.
Whispermode
Re: Looping waves (water) with noise texture - problem
Postby protovu » Wed Jun 02, 2021 1:22 pm
protovu Wed Jun 02, 2021 1:22 pm
I believe that I have been able to do precisely as you describe using the Graph Editor>Modifier>Cycles.
protovu
Postby Whispermode » Thu Jun 03, 2021 9:34 am
Whispermode Thu Jun 03, 2021 9:34 am
protovu wrote:I believe that I have been able to do precisely as you describe using the Graph Editor>Modifier>Cycles.
Thanks, protovu - this looks promising, but I don't think I explained it properly.
Effectively, I need the noise texture to return to its exact same state, so the animation itself loops rather than just the ability to loop something over time.
So, 120 frame animation. Frame 1 has a certain noise pattern. I translate on the Y by 1 unit between frame 1 and 120. By the time I get to frame 120 (or 121 actually), I need the noise pattern to have looped back to exactly what is was on frame 1.
...but it looks the noise texture is infinitely different as you translate i.e. I can't see any repetition at all. Which is normally great... :D
I think I'll have to just render out an image and tile it.
Whispermode
Postby promity » Thu Jun 03, 2021 4:16 pm
promity Thu Jun 03, 2021 4:16 pm
Make it loop in the video editors.
AMD Threadripper 1950X/64gb ram/RTX 3080 Ti + RTX 2070/Samsung SSD 870 EVO 500 gb/
Lightwave 3d
promity
Return to Blender
Users browsing this forum: No registered users and 26 guests
Sat Apr 27, 2024 12:07 pm [ UTC ]
