zdepth aov pass does not work
Forums: zdepth aov pass does not work
Moderator: aoktar
Postby smessing » Tue May 18, 2021 11:29 pm
smessing Tue May 18, 2021 11:29 pm
Hi, is the z-depth aov pass going to be fixed for c4d? It is very important and something I've requested for years within the live compositing features. I cannot get it to work at all as seen in Jules latest GTC2021 video. It shows up as a whited-out pass if I isolate the aov within the live viewer. If I change the max z-depth within the info channel kernel iteself it also has no affect on the aov pass. This happens on 2020.2.3-R4. I also do not see the weight parameter that Jules is sliding around in his demo to change the max depth. Why are things not consistent between releases? Is this function broken?
-Steven
smessing
Re: zdepth aov pass does not work
Postby aoktar » Wed May 19, 2021 12:56 am
aoktar Wed May 19, 2021 12:56 am
Nothing is broken, start with an AOV preset and select normalized-Z. Play with compositing parameters. I'm sure you'll find how to mix it.
Postby jayroth2020 » Wed May 19, 2021 1:52 am
jayroth2020 Wed May 19, 2021 1:52 am
Also, make sure you are using an appropriate file format, such as EXR(Octane).
CaseLabs Mercury S8 / ASUS Z10PE-D8 WS / Crucial 64GB 2133 DDR4 / 2 XEON E5-2687W v3 3.1 GHz / EVGA 1600 P2 / 1 EVGA RTX 3090Ti FTW3 Hybrid / 2 EVGA RTX 2080Ti FTW3 Hybrid/ Cinema 4D
jayroth2020
Return to Maxon Cinema 4D
Users browsing this forum: No registered users and 17 guests
Sun Apr 28, 2024 10:41 am [ UTC ]
