Fatal error: Segmentation fault
Forums: Fatal error: Segmentation fault
Houdini Integrated Plugin
Re: Fatal error: Segmentation fault
Postby juanjgon » Wed Dec 11, 2019 5:42 pm
juanjgon Wed Dec 11, 2019 5:42 pm
pm sent
juanjgon
Postby juanto_92 » Wed Dec 11, 2019 6:26 pm
juanto_92 Wed Dec 11, 2019 6:26 pm
Thaanks!!
juanto_92
Postby motionskill » Tue Dec 17, 2019 2:31 pm
motionskill Tue Dec 17, 2019 2:31 pm
I found that I have the same issue on scenes with many elements like Fur, Hair and when I hit "Update" in IPR. Reload button is working fine
motionskill
Postby juanjgon » Tue Dec 17, 2019 2:56 pm
juanjgon Tue Dec 17, 2019 2:56 pm
motionskill wrote:I found that I have the same issue on scenes with many elements like Fur, Hair and when I hit "Update" in IPR. Reload button is working fine
Hmm, I'm not sure if this is the same problem, because this crash was related directly to the reload function while rendering scenes in full scene reload mode. Can you please enable the Octane log file in the plugin options panel and attach the log that you get after one of these crashes?
juanjgon
Postby tschwenke » Tue May 04, 2021 7:59 am
tschwenke Tue May 04, 2021 7:59 am
Hi Juanjo,
Any chance I can get such a revised version. I'm still using 17.0.506 and 4.05.0.0 while having the same problem with a current project. A version where the "Full reload" function works would be nice :)
http://www.thomas-schwenke.me
Houdini 18.5 || Win10 || i7 + 1 x RTX3080
tschwenke
Postby tschwenke » Tue May 04, 2021 8:16 am
tschwenke Tue May 04, 2021 8:16 am
Or perhaps a hint what I can do to prevent the problem... Some scenes seem to work fine, others not, so there might be a simple solution by just doing something or not doing something.
tschwenke
Postby juanjgon » Tue May 04, 2021 9:20 pm
juanjgon Tue May 04, 2021 9:20 pm
Sorry, I'm afraid that Octane 4.05 is no longer supported. If you have this problem you could try to render the scene frame by frame using a script or a renderer controller like Deadline to avoid the scene reloading crash.
juanjgon
Postby tschwenke » Thu May 06, 2021 8:02 pm
tschwenke Thu May 06, 2021 8:02 pm
Ok, thank you though.
tschwenke
Previous
Return to Houdini
Users browsing this forum: No registered users and 19 guests
Sat Apr 27, 2024 11:31 pm [ UTC ]
