Issues with template start-up files
Forums: Issues with template start-up files
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Postby pegot » Sat Apr 03, 2021 7:19 pm
pegot Sat Apr 03, 2021 7:19 pm
Just installed 2020.2_2.34 and having an issue with template start-up files.
If I switch to a different template, such as Sculpting, Octane Render no longer shows up as a rendering option. Opening another default template (General, VFX, 2D Animation) still prevents Octane Render from showing as an option. However, preferences clearly shows the plugin is enabled. I can only get access to the Octane Render option by closing Blender and restarting.
I have come across this issue once before in an older build. This time though the problem also seems to be preventing me from making an Octane start-up template. I created the Octane template the way I always have previously (configuring my Octane set-up windows and saving the startup.blend file over a copy of one of the other templates in a folder named Octane). When I open this new Octane start-up template I get the following error: “engine ‘octane’ not available for ‘Scene’ (an add-on may need to be installed or enabled). But of course when I check preferences Octane is already enabled. Restarting Blender returns access to the Octane render engine - until I try to load a one of the other start-up templates.
Win 10
3.7Ghz i9 10900k / 64GB
ASUS STRIX Z490-E
PSU: PowerSpec 850Wd
RTX 3090 Asus Tuff
Network rendering:
Win 10
4.2Ghz i7 7700k / 64GB
AsRock SuperCarrier
PSU: EVGA 1200w
RTX 3080 Ti EVGA Hybrid
RTX 3080 ASUS Tuff
GTX 1080ti SC Black (wc)
pegot
Re: Issues with template start-up files
Postby grimm » Sat Apr 03, 2021 9:59 pm
grimm Sat Apr 03, 2021 9:59 pm
I'm not 100% sure on this, but I suspect that something has changed from when you first created the templates. You might have to re-create them to get it to work again.
Linux Mint 20 x64 | Nvidia GTX 980 4GB (displays) RTX 2070 8GB| Intel I7 5820K 3.8 Ghz | 32Gb Memory | Nvidia Driver 460.56
grimm
Postby pegot » Sun Apr 04, 2021 1:37 am
pegot Sun Apr 04, 2021 1:37 am
Nothing changed on my end except installing the new 2020.2_23.4 version. In fact I am on a brand new machine and the only other version I had on it thus far I think was the previous 2020.2_23.1 and never even created an Octane template for that version. However, that previous version which I still have installed dose not exhibit either of my problems with 2020.2_23.4.
Not only can I seamlessly switch between the Blender templates and have Octane render show up as a render option, but I am also able to create a specific Octane template that works. It is only the latest version that is spitting out the errors. I even uninstalled and re-installed it but problem persists.
Win 10
ASUS STRIX Z490-E
RTX 3090 Asus Tuff
Network rendering:
Win 10
AsRock SuperCarrier
PSU: EVGA 1200w
RTX 3080 ASUS Tuff
pegot
Postby grimm » Sun Apr 04, 2021 5:32 pm
grimm Sun Apr 04, 2021 5:32 pm
Yeah, sounds like a bug to me. Mostly I was thinking it would be a change in Blender itself, but this does not appear to be the case. I would test for you, but 23.4 crashes instantly in Linux when I turn on rendering. :(
Jason
grimm
Postby pegot » Mon Apr 05, 2021 1:59 am
pegot Mon Apr 05, 2021 1:59 am
Wow that is a much more serious problem. Wonder if this latest release is truly ready for prime time - though my issue thus far is the only one I have experienced in my limited usage with it.
Win 10
ASUS STRIX Z490-E
RTX 3090 Asus Tuff
Network rendering:
Win 10
AsRock SuperCarrier
PSU: EVGA 1200w
RTX 3080 ASUS Tuff
pegot
Postby linograndiotoy » Wed Apr 07, 2021 2:08 pm
linograndiotoy Wed Apr 07, 2021 2:08 pm
pegot wrote:Wow that is a much more serious problem. Wonder if this latest release is truly ready for prime time - though my issue thus far is the only one I have experienced in my limited usage with it.
"Why so serious?", someone would say.
We'll look into that. Right now just start with the General Template and switch to any workspace. It will work perfectly.
linograndiotoy
Postby pegot » Wed Apr 07, 2021 8:22 pm
pegot Wed Apr 07, 2021 8:22 pm
linograndiotoy wrote:"Why so serious?"
:D
Yes General is the default. It is just nice when starting a lot of test files to be able to quickly jump right to the Octane settings I need to adjust.
Win 10
ASUS STRIX Z490-E
RTX 3090 Asus Tuff
Network rendering:
Win 10
AsRock SuperCarrier
PSU: EVGA 1200w
RTX 3080 ASUS Tuff
pegot
Postby pegot » Wed Apr 21, 2021 1:26 pm
pegot Wed Apr 21, 2021 1:26 pm
FIXES SINCE LAST RELEASE: Fixed the Octane initialization failure when switching to a new template
Thank you for fixing!
Win 10
ASUS STRIX Z490-E
RTX 3090 Asus Tuff
Network rendering:
Win 10
AsRock SuperCarrier
PSU: EVGA 1200w
RTX 3080 ASUS Tuff
pegot
Postby linograndiotoy » Mon May 03, 2021 4:50 pm
linograndiotoy Mon May 03, 2021 4:50 pm
You're welcome!
linograndiotoy
Return to Bug Reports
Sun Apr 28, 2024 4:36 pm [ UTC ]
