OctaneRender™ 2020.2.1
Forums: OctaneRender™ 2020.2.1
Re: OctaneRender™ 2020.2.1 [current 2020.2]
Postby Kalua » Fri Mar 19, 2021 3:49 am
Kalua Fri Mar 19, 2021 3:49 am
Goldorak wrote:We will work on a simple light mix macro like the included one.
Look very intuitive! Good to have a simple solution and a more elaborated one!
Regards,
C4D 25.117 Octane 2022.1.2 R4, <<2 X 3090 + NVlink>>, Windows 10, X399, AMD TR 1950X, 128 GB RAM, NVIDIA SD 536.67
Kalua
Postby PolderAnimation » Fri Mar 19, 2021 3:44 pm
PolderAnimation Fri Mar 19, 2021 3:44 pm
I already requested this in 2017. But I think live-nodes or reference nodes are crucial.
my description from 4 years ago:
'A group that can function as a reference node. If you change anything in this group node and save it, it will automation change in all your files that contain this reference node. In big productions this is crucial. (In nuke this is called a live group in maya it is called a reference).'
Win 10 64bit | RTX 3090 | i9 7960X | 64GB
PolderAnimation
Postby linograndiotoy » Mon Mar 22, 2021 10:31 am
linograndiotoy Mon Mar 22, 2021 10:31 am
coilbook wrote:please fix fog. it's either black screen (too much) or no fog
Is it some issue you're having with a specific scene or a general issue?
Would it be possible to take a look at your node setup?
linograndiotoy
Postby Goldorak » Tue Mar 23, 2021 10:45 pm
Goldorak Tue Mar 23, 2021 10:45 pm
PolderAnimation wrote:I already requested this in 2017. But I think live-nodes or reference nodes are crucial.
I agree - and like switch nodes and scripted geometry nodes - it's doable in script nodes and this in standalone, but the issue is how to expose this cleanly across all theDCC tools - which already have limits based on host DCC for the dynamic graphs /script nodes that aren't hidden inside ORBX proxy objects.
Goldorak
Postby PolderAnimation » Sat Mar 27, 2021 9:34 am
PolderAnimation Sat Mar 27, 2021 9:34 am
When using an ABC camera that has a lens shift (camera offset from the backplate) the manipulators (for translate scale rotate) do not show on the right place (is does not correct for the shift in de lens).
PolderAnimation
Postby funk » Mon Mar 29, 2021 12:38 pm
funk Mon Mar 29, 2021 12:38 pm
BUG: Render region stops at 60 samples + CUDA crash
I have been running into an issue where drawing a render region stops rendering at about 60 samples.
A modo user (ErwinZwart) just sent me a reduced scene where this happens, so I'm posting it here.
1. Load orbx
2. Click render target to start rendering
3. Draw a render region as quick as possible
RESULT: It seems if you draw a region before Octane has reached a certain amount of samples, the render region stops rendering at 60.
Any new regions you draw also stop at 60. If you stop then start the render without clearing the region, the new region stops at 60 too.
EDIT: Also after drawing several regions and viewing some of the passes, I eventually get a CUDA error/crash too. I think it happens when the denoiser tries to run on a small region
Win10 Pro/ Ryzen 5950X / 128GB / RTX 4090 / MODO
funk
Postby ErwinZwart » Mon Mar 29, 2021 1:01 pm
ErwinZwart Mon Mar 29, 2021 1:01 pm
Thank you for reporting, Funk!
It is a real workflow killer in render-intensive scenes to not being able to use the region rendering. I have to wait for the whole frame to reach 60 samples and then can select a region. However when I want to view another region it gets stuck with CUDA errors often.
ErwinZwart
Postby galleon27 » Mon Mar 29, 2021 1:09 pm
galleon27 Mon Mar 29, 2021 1:09 pm
funk wrote:BUG: Render region stops at 60 samples + CUDA crash
1. Load orbx
Ok so i found the bug. I has something to do with Cryptomatte passes. When you disable it, it renders past 60 samples.
Win 10 64bit // GTX 4090 + GTX 3090 // 5900x // 64GB // SideFX Houdini // C4D
galleon27
Postby ErwinZwart » Mon Mar 29, 2021 2:25 pm
ErwinZwart Mon Mar 29, 2021 2:25 pm
Yes, that does the trick it appears. I wonder though, because I incidentally ran into this behavior for a long time, also before Cryptomatte was added to OctaneRender.
ErwinZwart
Postby PolderAnimation » Mon Mar 29, 2021 8:02 pm
PolderAnimation Mon Mar 29, 2021 8:02 pm
1. Load orbx
Correct I have used this trick for quite a while now. But would be great if they could fix this bug.
PolderAnimation
Previous
Return to Commercial Product News & Releases (Download here)
Users browsing this forum: No registered users and 5 guests
Sat Apr 27, 2024 10:08 am [ UTC ]
