2020.1.5-R4 & RTX 3090 not working at all
Forums: 2020.1.5-R4 & RTX 3090 not working at all
Sub forum for bug reports
Moderator: aoktar
C. RAM Capacity (i.e. 6 GB)
Re: 2020.1.5-R4 & RTX 3090 not working at all
Postby analog » Wed Dec 09, 2020 2:18 pm
analog Wed Dec 09, 2020 2:18 pm
lanklaf wrote:
analog wrote:I did that. Octane installed the same version again (cudnn64_7.dll) so still not working :(
BTW: Thanks a lot for your help!
Aha, ok:
You also can download it manualy:
https://render.otoy.com/downloads/ef/08 ... _4_win.zip
And unpack to this location:
C:\Users\USERNAME\AppData\Local\OctaneRender\thirdparty\cudnn_8_0_4
Maybe Octane is downloading an older version of cuDNN because you also have an RTX2000 card.
So it's better to do it manually.
I did this. Octane still wants me to install the 7_4_1
So I installed both, the 7_4_1 and the 8_0_4
Not working :(
Next thing i`ll try is to deactivate the 2080. Perhaps this works. Or I switch the PCI-E Slots...
System Specs
MB: Asus Pro WS X570-ACE
CPU: AMD Ryzen 3950x
GPU 1: NVIDIA RTX 3090FE
GPU 2: ASUS RTX 2080
RAM: Corsair Vengeance RGB pro 3200 4x16GB
OS: Win10 64bit
Cinema 4D R20
analog
Postby lanklaf » Wed Dec 09, 2020 2:22 pm
lanklaf Wed Dec 09, 2020 2:22 pm
Aha, ok:
Not working :(
It's a good idea to unplug the 2000 card.
Let's see if it works.
P.S. do not delete 8 cuDNN.
System:
i7 8700K / RTX 2020 / 16GB RAM
lanklaf
Postby analog » Wed Dec 09, 2020 2:24 pm
analog Wed Dec 09, 2020 2:24 pm
Aha, ok:
Not working :(
System Specs
OS: Win10 64bit
Cinema 4D R20
analog
Postby analog » Wed Dec 09, 2020 2:25 pm
analog Wed Dec 09, 2020 2:25 pm
Deactivating the rtx 2080 didn´t help. Octane still wants the 7-4-1
System Specs
OS: Win10 64bit
Cinema 4D R20
analog
Postby lanklaf » Wed Dec 09, 2020 2:29 pm
lanklaf Wed Dec 09, 2020 2:29 pm
analog wrote:Deactivating the rtx 2080 didn´t help. Octane still wants the 7-4-1
Try this:
System:
lanklaf
Postby analog » Wed Dec 09, 2020 2:38 pm
analog Wed Dec 09, 2020 2:38 pm
still not working. I`m getting mad :(
System Specs
OS: Win10 64bit
Cinema 4D R20
analog
Postby lanklaf » Wed Dec 09, 2020 2:40 pm
lanklaf Wed Dec 09, 2020 2:40 pm
analog wrote:still not working. I`m getting mad :(
:? :oops:
System:
lanklaf
Postby bepeg4d » Thu Dec 10, 2020 9:39 am
bepeg4d Thu Dec 10, 2020 9:39 am
Please download and run Standalone 2020.2-RC4:
viewtopic.php?f=33&t=76451
At first start, it should ask to upgrade the cuDNN library:
ciao Beppe
Postby analog » Thu Dec 10, 2020 12:43 pm
analog Thu Dec 10, 2020 12:43 pm
So finally it worked :)
After installing the new standalone-Version of Octane the Path in Cinema4D Octane Settings was wrong. After correcting it worked :mrgreen: :D
Thanks for your Help Guys!!
System Specs
OS: Win10 64bit
Cinema 4D R20
analog
Postby analog » Thu Dec 10, 2020 1:19 pm
analog Thu Dec 10, 2020 1:19 pm
So I did some tests on different heavy scenes i´m working on.
First thing I noticed is enabling RTX nearly halfs the Ms/sec. I know it depends on the scene but before working with the 3090 enabling RTX brought a huge boost on most of my projects.
Secondly I´m a little dissapointed of the performance. Working with two RTX 2080 was almost the same speed as working with a 3090 and a 2080. Not sure if I should keep the card.
Just saw that "Number of Cuda-Cores" is not showing for the 3090:
Could this be a problem?
P.S.: Temps are OK!
System Specs
OS: Win10 64bit
Cinema 4D R20
analog
PreviousNext
Return to Bug Reports
Users browsing this forum: Google [Bot] and 2 guests
Sun Apr 28, 2024 4:24 pm [ UTC ]
