Reset ALL light sampling rate to 1
Forums: Reset ALL light sampling rate to 1
Postby coilbook » Wed Nov 18, 2020 4:17 am
coilbook Wed Nov 18, 2020 4:17 am
Can we have a global button to Reset ALL light sampling rate (texture) to 1
With hundreds of light emitting textures or old light textures imported (each one has its own sampling rate set) and juggling between light sampling priorities among textures it would be nice to have this button.
coilbook
Re: Reset ALL light sampling rate to 1
Postby coilbook » Wed Nov 18, 2020 3:23 pm
coilbook Wed Nov 18, 2020 3:23 pm
Also please add automatic movable proxy. It's such a pain right now. You uncheck update static geometry and if some moving mesh is not check it'll be stationary. Why cannot the system, detect what moving and auto apply movable proxy.
coilbook
Postby bepeg4d » Thu Nov 19, 2020 7:27 am
bepeg4d Thu Nov 19, 2020 7:27 am
Hi coilbook,
your requests seems more related to your integrated plugin, than Standalone.
In Standalone there is not the Movable Proxy concept, since it is related to the creation of animated contents, so specifically related to plugins.
About Sample Rate in lights, in Standalone you should need a Lua script for that, while in an integrated plugin it should be easy to filter select all the lights in one go, and easily change the Sample Rate to all of them with a couple of clicks:
ciao Beppe
Postby coilbook » Thu Nov 19, 2020 6:42 pm
coilbook Thu Nov 19, 2020 6:42 pm
bepeg4d wrote:Hi coilbook,
ciao Beppe
HI, thanks. We also want to reset sampling rate inside emission textures to 1 not just octane lights. Not sure if it's possible
coilbook
Postby HHbomb » Sun Nov 22, 2020 9:07 am
HHbomb Sun Nov 22, 2020 9:07 am
You can try with Zorb tool... I'll see on monday?
HHbomb
Return to Development Build Releases
Users browsing this forum: No registered users and 11 guests
Sat Apr 27, 2024 7:58 pm [ UTC ]
