Octane X™ PR 4 for Big Sur
Forums: Octane X™ PR 4 for Big Sur
Postby haze » Tue Nov 10, 2020 3:53 am
haze Tue Nov 10, 2020 3:53 am
Hi all
This is our first public release of Octane X Standalone for Big Sur and includes support for AMD Polaris, Vega, Navi as well as Intel GPUs, along with full OSL support.
At the moment we have only the Studio standalone version to share, but we will add Enterprise as soon as we can, as well as the render node.
Important notes:
  • This build will only work on Big Sur and newer. Please also ensure you are running the very latest version of Big Sur, this is very important.
  • Please note that this release is marked "internal" because it is not code signed or notarized. It should work just fine, but if you have any issues opening and running Octane, the workaround is to right click, then click open.
  • This build should still be considered an experimental build. Please be careful not to use this for important production work.
  • We are currently aware of two significant issues. One is a hang that triggers in a very specific situation. The other is that on the newest MacBook Pro 2020 (with the IceLake processor), Octane is currently not able to render. We welcome any other feedback, and thank you in advance for this.
Changes since PR3
  • Make the numeric boxes in the node inspector more robust.
  • Workaround for a compiler issue in material preview
  • Fixed missing application of the max. speed parameter to motion vector AOVs
  • Fixed OSL projection
  • Fixed vertex displacement
  • Fixed motion blur on vertex displaced objects
  • Fixed AI Light updating issue
  • Fixed a crash when rendering a mix material containing a volume medium
Download
Downloads for Studio subscription users:
Octane X Studio Standalone for MacOS 11
Downloads for Enterprise subscription users:
Octane X Enterprise Standalone for MacOS 11 - Coming soon!
Octane X Enterprise Network Rendering Node for MacOS 11 - Coming soon!
haze
Re: Octane X™ PR 4 for Big Sur
Postby plasmapeppers » Thu Nov 12, 2020 6:04 pm
plasmapeppers Thu Nov 12, 2020 6:04 pm
So, the Big Sur update is here - is there an ETA on enterprise? Or can enterprise subs use the Studio version for the time being? I would like to get onto Big Sur as soon as possible!
CUDA
i7-7820X 96GB + 1080Ti
i7-8650U 16GB + 1060M
Metal
Mac mini i7-8700B 32GB + Radeon VII eGPU
plasmapeppers
Postby Goldorak » Fri Nov 13, 2020 12:21 am
Goldorak Fri Nov 13, 2020 12:21 am
It take a while to build each tier, Enterprise is coming next, then plug-in SDK for the dcc plugins and if all is done then prime/demo
Goldorak
Postby JoGo23 » Fri Nov 13, 2020 10:27 am
JoGo23 Fri Nov 13, 2020 10:27 am
Goldorak wrote:It take a while to build each tier, Enterprise is coming next, then plug-in SDK for the dcc plugins and if all is done then prime/demo
Just to confirm, does it mean that PR3 won't work under Big Sur ?
JoGo23
Postby bepeg4d » Fri Nov 13, 2020 11:11 am
bepeg4d Fri Nov 13, 2020 11:11 am
Yes confirmed, PR3 is Catalina only.
ciao Beppe
Postby JoGo23 » Fri Nov 13, 2020 2:19 pm
JoGo23 Fri Nov 13, 2020 2:19 pm
bepeg4d wrote:Yes confirmed, PR3 is Catalina only.
ciao Beppe
Thanks for the clarification. I'll stick with Catalina a little longer then.
JoGo23
Postby plasmapeppers » Sat Nov 14, 2020 3:34 pm
plasmapeppers Sat Nov 14, 2020 3:34 pm
Well it works pretty well so far! Only thing is that PMC crashes instantly with my Radeon VII eGPU. Doesn't matter the scene, just add a render target, change kernel to PMC, crashes. PMC does still work on the Intel iGPU, but that is ...
Anyways, it doesn't work with both enabled either, if the VII is in the mix it crashes.
Hardware:
Mac mini i7-8700B + 32GB RAM (2018) and Razer Core X eGPU with Radeon VII
macOS Big Sur 11.0.1
CUDA
Metal
plasmapeppers
Postby HelgeKiehl » Tue Nov 17, 2020 4:57 pm
HelgeKiehl Tue Nov 17, 2020 4:57 pm
trying to get this up and running but im crashing into these problems. (attached)
Any Ideas how what could cause these problems?
best,
Helge
Loaded Octane DLL:Octane X Studio PR4 version:10000200 SDK:PR4
Octane X for Cinema 4D PR4 built for:230 C4D vers:23008
C4D:23008 comp:[xxx's iMac Pro] OS:[OS X 64 BIT] OS X: Version 10.16 (Build 20B29) versType:10
CPU:[GenuineIntel, stepping 4, model 5, instruction family 6] speed:3.2 GHz numOfCpu:16Ht
Plugins:[houdiniconfig addons advanced_render alembic archigrass bitmapfilter bpexchange browser bugslife_client c4d_viewport_render c4doctane-R23 ca ca2 cadexchange clothilde collada14 collada15 colorchoosergui compositing deltamush deployment dwg dwgobjects dynamics exchanges expressiontag fbx gltf goz hair i_skp interop io_obj metrics mkmodeler mocca model mograph motioncam motiontracker nbo nbp newman nodeeditor objects onlineupdater projectassetinspector python relaxuv sculpt sculptbrushes shader sketch sky sla spacemouse substance teamrender thinking_particles tpoperators usd uvviewport volumes xpressocore xtensions ]
Loaded 90 osl scripts from dir:/Users/xxx/Library/Preferences/Maxon/Maxon Cinema 4D R23_2FE1299C/plugins/c4doctane/res/osl_scripts
VRAM used/free/max:0Kb/15.984Gb/15.984Gb Out-of-core used:0Kb RAM used:16.653Gb total:32Gb OpenGL free/total:0/0
File not found:/Users/xxx/Library/Preferences/Maxon/Maxon Cinema 4D R23_2FE1299C/updates-ox.txt
FumeFx library initialisation error!
Multi-threaded material conversion, thread count=14
Export materials time= 0.131 ms
Collect objects time= 0.154 ms
Mesh creation time = 2.79 ms.
Api update time: 0.044 ms.
<<< Render failure detected!!! >>>
Please check render statistics to solve the problem.
MB:0/0 ST/MOV:0/1 Nodes:12 Tris:12 DispTris:0 Hairs:0 Meshes:1
Textures Grey8/16:0/0 Rgb32/64:0/0
Started logging on 17.11.20 18:49:00
Octane X Studio PR4 (10000200)
Compute error 2097152:116:
compute device 1: Linking 6d197dfc90d19e72 shader failed
compute device 0: Linking 6d197dfc90d19e72 shader failed
device 0: failed to initialize render thread 0x7fb534378750
device 1: failed to initialize render thread 0x7fb534379140
device 0: failed to initialize render thread 0x7fb573f42fd0
device 1: failed to initialize render thread 0x7fb573f46e60
could not pick, because we have no render threads
device 0: failed to initialize render thread 0x7fb621d33240
device 1: failed to initialize render thread 0x7fb621d2e710
HelgeKiehl
Postby aoktar » Tue Nov 17, 2020 5:02 pm
aoktar Tue Nov 17, 2020 5:02 pm
HelgeKiehl wrote:Hi,
There's not yet any C4D-PR4 plugin build for BIG SUR. You should be using a Catalina build, no surprising to get crashes because of this. It will not work with that, wait for a proper Big Sur C4D build
Postby HelgeKiehl » Tue Nov 17, 2020 5:20 pm
HelgeKiehl Tue Nov 17, 2020 5:20 pm
Ahh my bad, sorry. I mixed up the plugin and Standalone release. I'll wait, thank you!
HelgeKiehl
Next
Return to Development Build Releases
Sat Apr 27, 2024 11:53 am [ UTC ]
