Standalone preview not showing
Forums: Standalone preview not showing
Postby pgatsky » Mon Nov 02, 2020 1:21 pm
pgatsky Mon Nov 02, 2020 1:21 pm
Hi all
Ive just started to look at more depth at the Standalone octane app. Ive been using octane now for just under a year but with C4D and recently updated plugin to 456.71 (studio driver) as when i updated the pluin for C4D the preview under old driver wouldn't work, It now does with new driver.
I can open files up ok in the standalone and everything seems to be there but I cant see any preview so not sure if im doing something wrong or if i need to get a different driver? I'm attaching screen shots to show what I'm seeing.
Thank you all for any help on this.
pgatsky
Re: Standalone preview not showing
Postby pgatsky » Mon Nov 02, 2020 1:46 pm
pgatsky Mon Nov 02, 2020 1:46 pm
Found the problem so no problem ;-)
pgatsky
Postby klc3d » Thu Nov 12, 2020 11:19 pm
klc3d Thu Nov 12, 2020 11:19 pm
Can you explain the solution? I'm new to Octane and having the same issue. Since I'm new, I have no idea if I'm overlooking something or if it's a bug.
klc3d
Postby pgatsky » Fri Nov 13, 2020 9:06 am
pgatsky Fri Nov 13, 2020 9:06 am
Hi klc3d
All i did in the end was add a render target node after looking at example files. That seems to activate the preview window into working. Was nothing to do with drivers etc. Hope that helps you.
pgatsky
Postby klc3d » Sat Nov 14, 2020 1:29 pm
klc3d Sat Nov 14, 2020 1:29 pm
That did the trick. Thanks!
klc3d
Users browsing this forum: No registered users and 43 guests
Sun Apr 28, 2024 12:49 pm [ UTC ]
