Postby james_conkle » Sat Aug 01, 2020 7:24 pm
james_conkle Sat Aug 01, 2020 7:24 pm
aoktar wrote:Scaling the canvas of live viewer is on my TODO list. It's complicated for me than you estimate because of current features of Live Viewer. So not will come immediately or soon
I can't imaging how working on any of this is not complicated :oops: Just glad to know it's on your radar :) <3 Thank you
Octane C4D Plugin 2021.1 / C4D R25.015
UNIT 0: 2080ti / 6700K / 64GB / 500w
UNIT 1: 2x 3090 / 3970x / 128GB ECC / 1600w
UNIT 2: 5500M / 9980HK / 32GB / 95w
RNDR Artist Calculator
james_conkle
Postby 19Nik90 » Sat Aug 01, 2020 10:27 pm
19Nik90 Sat Aug 01, 2020 10:27 pm
On my MacBook Pro 2018 with Radeon Pro 555X it says "No GPU Selected", when I select it, it deselect automatically. Is it compatible?
Thank you
19Nik90
Postby aoktar » Sun Aug 02, 2020 10:54 pm
aoktar Sun Aug 02, 2020 10:54 pm
Trying to implement CANVAS SCALING without changing the resolution. Is this what you want?
Postby CarlsBad » Sun Aug 02, 2020 11:53 pm
CarlsBad Sun Aug 02, 2020 11:53 pm
19Nik90 wrote:On my MacBook Pro 2018 with Radeon Pro 555X it says "No GPU Selected", when I select it, it deselect automatically. Is it compatible?
Thank you
I don't believe any of the Radeon 5xx series cards (discrete or desktop) are supported. All of those predate the Vega and Navi series cards.
CarlsBad
Postby james_conkle » Mon Aug 03, 2020 1:13 am
james_conkle Mon Aug 03, 2020 1:13 am
aoktar wrote:Trying to implement CANVAS SCALING without changing the resolution. Is this what you want?
Hi Aoktar (take the weekend off!), yes that looks like that's what we're asking for. Hard to tell since I don't see you adjusting the scaling via a drop down or entering a number. I've attached an image where when I lock the resolution at "1" for a 1920x1080 project in a window on my 4k monitor it's small. To get Octane to fill the space I set the lock at "1.4" but I'm loosing some speed since I'm rendering more pixels than I will on the final image.
I've also attached an image on how redshift (I know it's a bad word) has implemented this feature. Sorry if I'm not explaining this well, but thank you.
james_conkle
Postby Pixege » Mon Aug 03, 2020 9:08 am
Pixege Mon Aug 03, 2020 9:08 am
Wow this looks very promising!
MacBook Pro 16" | AMD Radeon Pro 5500M 8 GB | 2,3 GHz Intel Core i9 | 64 GB RAM + eGPU Razer Core X | Asus ROG Strix RX 5700 XT OC
Pixege
Postby DERJUNG » Mon Aug 03, 2020 11:06 am
DERJUNG Mon Aug 03, 2020 11:06 am
yes, it looks much better than this tiny square zooming :-)
MacPro 12 [email protected] Ghz - 48GB 2933Mhz DDR4 - AMD Radeon Pro Vega II Duo 32GB
DERJUNG
Postby keithrondinelli1974 » Mon Aug 03, 2020 1:22 pm
keithrondinelli1974 Mon Aug 03, 2020 1:22 pm
Yes, Arnold has a similar IPR scaling feature that I found incredibly useful. Two difference controls, "Scale," which literally scales the set pixel dimensions of the render settings, so, if you have your render set at 1920x1080, and set the IPR "Scale" to 50%, it's actually rendering 960x540. Then, "Zoom" which ignores any settings and just allows you to zoom in and out on the image, irrespective of render settings. So, you could then set "Scale" to 50% and "Zoom" to "200%" and have a 1920x1080 preview at half resolution, which would speed up preview rendering considerably and still allow you to get a bit closer to the image. I'd often set my "Scale" to somewhere around 80% and Zoom to 120% and it would give me a nice bump up in speed without really sacrificing much detail.
keithrondinelli1974
Postby JoGo23 » Mon Aug 03, 2020 2:26 pm
JoGo23 Mon Aug 03, 2020 2:26 pm
Hi Goldorak. Any updates on Modo plugin errors?
JoGo23
Postby enb300 » Mon Aug 03, 2020 8:41 pm
enb300 Mon Aug 03, 2020 8:41 pm
Hi! New to octane here,
I'm trying to use a vertex map as a mask in a composite material but I can't for the life of me get it to work! I'm attaching a screenshot with my material/viewport. This is driving me crazy as I can't figure out what's going wrong!
(also, I'm using Cinema 4D S22 on a MacBook Pro just fyi)
enb300
PreviousNext
Return to Foundry Modo
Users browsing this forum: No registered users and 18 guests
Fri Apr 26, 2024 2:24 pm [ UTC ]
