I suggest re-rendering the animation, and not disabling the cards during the process to determine if that is the problem or not.Also had a strange issue. I rendered a Sequenz (0-125 Framerange). It only rendered till Frame 121 and said it was done. The Frames are namend 0 till 121, but it skipped some frames so Frame 125 is named 121. During Rendering i disabled two Cards. Is it possible that this caused the issue?
This is an Octane engine issue - which I will report to OTOY.Hesekiel2517 wrote:
The Text says this value in the Dirtnode can be 0.0 but the minimum is 1.0
Updating Round Edges nodes pin values seems to be updating correctly in the next version of the plugin. As for the create.octane.emitter command not bring across any images, yes, that is a limitation of the current create.octane.emitter command. Visibility settings worked for me, as turning of the parent light also turned off the geometry emitter.Hesekiel2517 wrote:Hey Paul,
if i change the values of the Rouded edge node i need to update the scene to see an effect. Also if i have an image applied to an Arealight and click "create octane emitter" the image is not included in the resulting emitter material. Also "General Visibility" and "Sampling Rate" are not taken into account.
Thank you for your work!
Hi. This looks like an Octane render engine issue rather than a plugin issue, so you will need to report it to OTOY via the Support button at the top of this page, or in the OctaneX forum.DERJUNG wrote:Hi, Paul,
unfortunately the plugin for Octane X does not work in Modo 14.0v2 I am on a MacPro7,1 with a Vega II Duo and Catalina 10.15.6.
In Cinema 4D R21 everything works. Strange. Am I doing something wrong with the installation or is it a mistake?
Started logging on 22.07.20 09:17:34
Octane X Enterprise PR1 (10000024)
Compute error 2097152:113:
compute device 1: Linking 6d197dfc90d19e72 shader failed
compute device 0: Linking 6d197dfc90d19e72 shader failed
device 1: failed to initialize render thread 0x7fc6aee1a270
device 0: failed to initialize render thread 0x7fc6aee19930
Users browsing this forum: No registered users and 53 guests
