Octane 2020 For Unreal Engine - v0.33: Animated ORBX Export
Forums: Octane 2020 For Unreal Engine - v0.33: Animated ORBX Export
Moderator: ChrisHekman
Re: Octane 2020 For Unreal Engine - v0.33: Animated ORBX Export
Postby ChrisHekman » Fri Mar 27, 2020 2:05 pm
ChrisHekman Fri Mar 27, 2020 2:05 pm
StyleMarshal wrote:Both FBX/SkinnedMesh morphtargets and alembic geometry cache should work.
Yes , works fine here.
Chris did you have taken a look to the new Groom System in UE4.25?
Do you think it will be possible to render in Octane Plugin in the future ?
Full body test here :
Octane does support hair rendering, and unreal hair system seems similar.
We are definitely interested in supporting it.
ChrisHekman
Postby StyleMarshal » Fri Mar 27, 2020 2:23 pm
StyleMarshal Fri Mar 27, 2020 2:23 pm
Super , thank you !
If you need alembic hair for tests, you can download my test hair in the description of the video. It fits to the Mannequin.
StyleMarshal
Postby ChrisHekman » Fri Mar 27, 2020 2:30 pm
ChrisHekman Fri Mar 27, 2020 2:30 pm
StyleMarshal wrote:Super , thank you !
Thanks, that helps a lot. I was actually looking for example alembic models with hair.
ChrisHekman
Postby StyleMarshal » Tue Apr 14, 2020 1:17 pm
StyleMarshal Tue Apr 14, 2020 1:17 pm
Hi Chris ,
hope you are fine.
Another question :
Is it possible to render Media Files (Media Player , IMG Media Source) files with Octane ?
I am doing a project with a lot of animated emission materials , all is working fine in UE4 , but I can't get it to render in Octane Plugin.
Or am I doing something wrong ?
Here are my settings :
thx for your hard work !
StyleMarshal
Postby ChrisHekman » Mon Apr 20, 2020 10:39 am
ChrisHekman Mon Apr 20, 2020 10:39 am
StyleMarshal wrote:Hi Chris ,
hope you are fine.
Another question :
I take it this uses unreal texture streaming? This isnt supported atm, but is on the todo list.
ChrisHekman
Postby Renbry » Sat Apr 25, 2020 2:49 am
Renbry Sat Apr 25, 2020 2:49 am
Hi there!
I've done a bit of testing and can't get an ORBX Sequencer export that has the camera animating correctly. The ORBX opens up in Standalone with a static camera that isn't in the position of the camera i had locked in Sequencer. Sequencer renders the correct camera with i use the Octane image sequence option but i'm stuck not getting the camera out into the ORBX file.
Is this a bug ?
UE4 4.24.3 and using v.033 Octane for Unreal.
Renbry
Postby ChrisHekman » Tue Apr 28, 2020 5:12 pm
ChrisHekman Tue Apr 28, 2020 5:12 pm
Renbry wrote:Hi there!
Is this a bug ?
That is a bug. Ill check it out.
ChrisHekman
Postby Renbry » Thu Apr 30, 2020 9:50 am
Renbry Thu Apr 30, 2020 9:50 am
Hi Chris,
Really appreciate it ! Looks like the fix came through on the new release.
High five !
Renbry
Previous
Return to Releases
Mon May 06, 2024 12:43 pm [ UTC ]
