OctaneRender 4.05 for LightWave Production build 4.05.0.0
Forums: OctaneRender 4.05 for LightWave Production build 4.05.0.0
Re: OctaneRender 4.05 for LightWave Production build 4.05.0.0
Postby juanjgon » Tue Jan 07, 2020 6:30 pm
juanjgon Tue Jan 07, 2020 6:30 pm
No problem! I'm glad that the problem has been resolved.
juanjgon
Postby BraceMedia » Thu Jan 23, 2020 6:25 pm
BraceMedia Thu Jan 23, 2020 6:25 pm
Will this plugin v4 be updated to install with LW2020, when it is released?
BraceMedia
Postby juanjgon » Thu Jan 23, 2020 9:14 pm
juanjgon Thu Jan 23, 2020 9:14 pm
Hmm, probably not. We don't have any planned updates related to the current Octane 4.0x plugins. Any new LightWave version will be supported in the Octane 2019.1 and Octane 2020.1 plugins.
juanjgon
Postby BraceMedia » Sat Jan 25, 2020 9:48 am
BraceMedia Sat Jan 25, 2020 9:48 am
Will we be able to 'try' to install the plugin as normal, in 2020? Or will that not work at all?
BraceMedia
Postby juanjgon » Sat Jan 25, 2020 5:41 pm
juanjgon Sat Jan 25, 2020 5:41 pm
Sorry, I'm fairly sure that the LW 2019 plugin is not going to work in other newer LW versions but let's see once available.
juanjgon
Postby BorderLine » Mon Jan 27, 2020 10:21 am
BorderLine Mon Jan 27, 2020 10:21 am
Hi JuanJo,
How works Out of core geometry please ?
BorderLine
Postby juanjgon » Mon Jan 27, 2020 10:24 am
juanjgon Mon Jan 27, 2020 10:24 am
BorderLine wrote:Hi JuanJo,
It is enabled automatically when you enable the out of core option in the plugin options panel. The same option enables the out of core for the textures and for the geometry.
juanjgon
Postby BorderLine » Mon Jan 27, 2020 10:36 am
BorderLine Mon Jan 27, 2020 10:36 am
Thanks !
BorderLine
Postby BorderLine » Mon Jan 27, 2020 4:11 pm
BorderLine Mon Jan 27, 2020 4:11 pm
JuanJo,
If I understand correctly, the memory limit (texture and geometry) becomes the limit that I indicate to him in "out of core", in addition to my card memory ?
So I'm no longer limited to my GPU memory.
Crazy !
BorderLine
Postby BorderLine » Mon Apr 27, 2020 1:58 pm
BorderLine Mon Apr 27, 2020 1:58 pm
Hi JuanJo,
IS it Ok for LW 2020 ?
BorderLine
PreviousNext
Return to Releases
Sat Apr 27, 2024 4:44 am [ UTC ]
