Extrude part of objects makes error with displacement
Forums: Extrude part of objects makes error with displacement
Postby kevin1998223 » Thu Jan 16, 2020 9:16 am
kevin1998223 Thu Jan 16, 2020 9:16 am
Hi, newbie here.
I'm using octane render and find out this problem while messing around, so I simply grab a cube to do some testing.
We can see only the part I extrude made these weird line that didn't cover the whole cube. (This can be fixed with projection but it still feels wrong to me cause it's just a simple object still)
https://imgur.com/a/Z94TEBD
And when I apply displacement on it, the part disappear entirely.
https://imgur.com/a/YPMIqoe
I can't figure out what exactly cause this. I'd done research and seeing someone else talking about it's two points that doubled confused the render engine or something like that, but it doesn't connect to me if a simple extrude cause this.
Can anyone explain the reason, and how to fix this? Appreciated!
kevin1998223
Re: Extrude part of objects makes error with displacement
Postby affixxius » Thu Jan 16, 2020 9:38 am
affixxius Thu Jan 16, 2020 9:38 am
The lines you see are the texture stretching due to the UVs changing when you extruded. Same thing with the displacement. Before texturing, you must consider whether you have correct UVs.
This vid might help with UV basics
https://www.youtube.com/watch?v=O72fjPg ... 72fjPg4YX8
I hope this helps, good luck!
// Windows 10 // 2 x RTX3080 // 4x GTX1080Ti // Octane Latest // Cinema 4D 2024 //
affixxius
Postby kevin1998223 » Fri Jan 17, 2020 7:04 am
kevin1998223 Fri Jan 17, 2020 7:04 am
affixxius wrote:The lines you see are the texture stretching due to the UVs changing when you extruded. Same thing with the displacement. Before texturing, you must consider whether you have correct UVs.
Oh thanks!
I found out the problem on my side is that I never noticed there's another projection tag under the texture tag during watching the video, and I used to only use the projection node in octane texture.
Problem solved, huge thx!
kevin1998223
Users browsing this forum: No registered users and 37 guests
Sun Apr 28, 2024 10:39 am [ UTC ]
