Which feature do you need the most?
Forums: Which feature do you need the most?
Volumetric: fire, smoke, clouds
368
17%
Hair&Fur
284
13%
Render Passes
237
11%
Particles
224
10%
Mixing of daylight and HDRI environment
210
9%
Multilight
155
7%
Region Render
139
6%
Rounded edges
130
6%
Multi UV channels
129
6%
Undo
103
5%
Internal Texture Mapping (planar, box, spherical, cylindrical, camera and so on)
86
4%
Network render
83
4%
Subdivision surfaces (OpenSubDiv)
80
4%
Total votes : 2228
Re: Which feature do you need the most?
Postby fantome » Thu Jul 11, 2019 8:34 am
fantome Thu Jul 11, 2019 8:34 am
extend support for color vertex attribute and float vertex attribute to
- curves object
- particles object
fantome
Postby scooternva » Tue Jul 23, 2019 5:34 pm
scooternva Tue Jul 23, 2019 5:34 pm
For the LightWave plugin, it would be nice if Octane's nodes were more closely integrated with the standard LightWave nodes.
  1. The LightWave "Input" and "Instance Info" nodes have all kinds of useful data points that would be invaluable as inputs for Octane material and texture nodes where randomness and/or instanced objects need to have their textures/materials varied based on position, distance from the camera, etc.
  2. The LightWave Math nodes would greatly expand on the limited math functions available in Octane.
Octane 2020.2.3.1 | LightWave 2019.1.5 (3134) | Win10 Pro 19041.1052 | 2 x Gigabyte AORUS RTX 2080 Ti Xtreme w/NVLink | Gigabyte AORUS Xtreme X399 | AMD Ryzen 2950X | 64 GB RAM | SSDs: Samsung 970 PRO 512 GB + Seagate FireCuda 510 2 TB | blog.gammans.zone
scooternva
Postby Goldorak » Wed Jul 24, 2019 9:44 am
Goldorak Wed Jul 24, 2019 9:44 am
scooternva wrote:For the LightWave plugin, it would be nice if Octane's nodes were more closely integrated with the standard LightWave nodes.
This could be solved with OSL state and utility nodes. They exist, but we plan to bake them in by 2019.2 RC1
Goldorak
Postby scooternva » Tue Jul 30, 2019 6:50 pm
scooternva Tue Jul 30, 2019 6:50 pm
Re the OSL nodes: It would be nice if the OctaneRender plugin for LightWave behaved more like standalone OctaneRender as far as the user interface is concerned. Simple example: your own Mandlebrot example (https://docs.otoy.com/osl) in the online documentation. In standalone OctaneRender there's a nice set of sliders for the numeric inputs. In LightWave, all you get are the connection pins. This is especially a problem with enum-type inputs (e.g., "mapper"), and it makes using string inputs (e.g., to select a filename) impossible. This really needs to be addressed.
scooternva
Postby fantome » Tue Sep 03, 2019 9:15 am
fantome Tue Sep 03, 2019 9:15 am
Nested Dielectric
fantome
Postby Notiusweb » Fri Sep 20, 2019 12:55 pm
Notiusweb Fri Sep 20, 2019 12:55 pm
1) Splash Screen on Load, with a racing sound.
2) Also, visible moving flames around the render speed while render is taking place. The render speed itself (font) could pulse between white and glowing red.
3) Finally, when you activate RTX mode in Preferences, a deep dramatic voice that would say "R-T-X....ENGAGED"
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
Notiusweb
Postby itsallgoode9 » Wed Oct 09, 2019 5:23 am
itsallgoode9 Wed Oct 09, 2019 5:23 am
fantome wrote:Nested Dielectric
for the love of god, please add this. there are SO many issues working with dielectric surface interactions that it's not even funny. other render engines have had this for years...YEARS :roll:
Intel i7-3930K, 64gb RAM, Asus X79 Deluxe mobo, 2x EVGA 780 6gb (for rendering), 1x PNY quaddro k4000 (for display)
Windows 8.1 x64, Maya 2014, Octane Render v2
itsallgoode9
Postby fantome » Fri Oct 11, 2019 10:03 am
fantome Fri Oct 11, 2019 10:03 am
in the scatter node of Octane Standalone, ability to edit the default input field
M00 M01 M02 M03 M10 M11 M12 M13 M20 M21 M22 M23
To be able to add :
1 - vector v attribute for motion blur computation of each instance or compute the motion vector pass correctly
M00 M01 M02 M03 M10 M11 M12 M13 M20 M21 M22 M23 V
2 - custom attributes that will be accessible with an instance color data or instance grayscale data node. for exemple we could add C1 for color attribute and F1 for float attribute.
M00 M01 M02 M03 M10 M11 M12 M13 M20 M21 M22 M23 V C1 F1
fantome
Postby Notiusweb » Wed Oct 16, 2019 12:55 am
Notiusweb Wed Oct 16, 2019 12:55 am
on Scene import,
FBX Morph Shapes, aka Blendshapes
Plugs: Enterprise
Notiusweb
Postby gabriele » Thu Nov 07, 2019 2:20 pm
gabriele Thu Nov 07, 2019 2:20 pm
I think also a Rules of third overlay....will be nice for complex scene!
gabriele
PreviousNext
Return to General Discussion
Mon May 13, 2024 11:51 am [ UTC ]
