Parallax projections HELP
Forums: Parallax projections HELP
Postby Jolbertoquini » Mon Jun 24, 2019 1:03 pm
Jolbertoquini Mon Jun 24, 2019 1:03 pm
Hi Guys,
I was looking around for OSL script for parallax mapping projection and Find this one here http://www.racoon-artworks.de/?p=773 is working for me on the orbx attached I jsut don't know how to changes some parts there to make work.
First is the UVW is based on world space I guess need be on Object space, also then be able to scale the texture as usually UV projection.
This could be really interesting for some projects. Please any help would be great for those who control better the OSL scripting.
Best,
JO
Parallax_mapping.zip
orbx scene
(10.55 MiB) Downloaded 485 times
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
Jolbertoquini
Re: Parallax projections HELP
Postby Jolbertoquini » Tue Jun 25, 2019 9:19 am
Jolbertoquini Tue Jun 25, 2019 9:19 am
Jolbertoquini wrote:Hi Guys,
Best,
JO
I was speaking with @Pascal and he gave me a great idea to replace the line "vector uvwIn = vector(u,v,0)" by "point uvwIn = P" and is working better get the texture displayed properly but I fell the parallax has a offset on the x axis on the UV I don't know how to get that fixed we still looking at :)
Jolbertoquini
Postby Jolbertoquini » Tue Jun 25, 2019 12:56 pm
Jolbertoquini Tue Jun 25, 2019 12:56 pm
Hi Guys
It's Alive is working Guys... here scene attached, I think need be adjust the OSL script I'm terrible with that but is working, maybe Dev Team could actually propose a new octane projection node? or just help and have a more clean script.
Big shout out to Pascal and Fadj for the help. they point out some solutions after testing a bit is better!
Here the scene attached.
Best,
JO
Parallax_mapping_Final.zip
Orbx scene
(8.05 MiB) Downloaded 367 times
Jolbertoquini
Postby noldo » Tue Jun 25, 2019 1:09 pm
noldo Tue Jun 25, 2019 1:09 pm
Thank's!!!
noldo
Postby Jolbertoquini » Tue Jun 25, 2019 2:20 pm
Jolbertoquini Tue Jun 25, 2019 2:20 pm
Hi Guys,
Here a new scene, I adjust a bit actually the 2d transform was wrong my bad! here a great result with other type of texture.
Cheers,
JO
render
Parallax_Fire.zip
Orbx_scene
(5.65 MiB) Downloaded 339 times
Jolbertoquini
Postby noldo » Tue Jun 25, 2019 6:03 pm
noldo Tue Jun 25, 2019 6:03 pm
I try your shader, great result but the shading seems inverted along 1 axis...
I try to investigate.
Edit. Found it, it works with the normal map y inverted.
noldo
Postby Jolbertoquini » Tue Jun 25, 2019 7:10 pm
Jolbertoquini Tue Jun 25, 2019 7:10 pm
noldo wrote:I try your shader, great result but the shading seems inverted along 1 axis...
Yes please take the latest orbx scene you can see better I had to invert stuffs to make work please check texture settings and etc.
This will help.
If we are lucky dev team could help us to get something better :)
Cheers,
JO
Jolbertoquini
Postby VVG » Wed Jun 26, 2019 7:52 am
VVG Wed Jun 26, 2019 7:52 am
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
VVG
Postby Jolbertoquini » Wed Jun 26, 2019 9:10 am
Jolbertoquini Wed Jun 26, 2019 9:10 am
VVG wrote:Thanks!
You welcome is a wip, please don't hesitate to share it if you find something better for the script, we manage to get without flip but require more samples, but also we try to get the height texture to be like a imager node cause this case we can tile the textures please let us know.
Cheers,
JO
Jolbertoquini
Postby Jolbertoquini » Wed Jun 26, 2019 9:53 am
Jolbertoquini Wed Jun 26, 2019 9:53 am
Hi There,
The best results are with 2019's beta with OC4.0.5 doesn't work really well the OSL I realize this morning I don't why I guess was some OSL updates...
Best,
JO
Jolbertoquini
Next
Return to Development Build Releases
Sun Apr 28, 2024 2:28 pm [ UTC ]
