Silverwing wrote:Hi Ahmat. Thank you for this release.
I have a question:
Can there something be done about the rather large compression when saving OpenEXR from the octane save menue.
I usually save through C4D because of that. But with for example Render Layers Black Shadow, this is not possible (needs to go through Octane save dialog)
When I do that, I usually get much larger EXR files.
This is not completely release depended as I noticed that behavior in versions before.
I hope you see what I mean.
I would really appreciate if you can take a look an eventually come up with a solution.
Thank you for your great work.
I attached a simple scene file. Make sure the output paths are matching your machine.
As you probably understand it´s not about the scene, its about the EXR File size compared between C4D and Octane.
Cheers,
Raphael
You'll lose the some functionality if you use C4D's saving path for render layers. Always use Octane's saving path for passes and take a look for new EXR-Octane type. It's just not supporting the RenderLayer Masks but rest should be ok with good compression.
