Attribute Workflow *FIXED
Forums: Attribute Workflow *FIXED
Houdini Integrated Plugin
Re: Attribute Workflow
Postby daryl.dunlap » Mon Jan 07, 2019 6:02 pm
daryl.dunlap Mon Jan 07, 2019 6:02 pm
aLeXXtoR wrote:Could you please help me with the primitive color attribute — what setup I must do in Houdini to use that colors with my mesh material?
For now, you'll have to manually transfer all attributes that you want to use in Shading to the Point Attribute level.
daryl.dunlap
Postby aLeXXtoR » Tue Jan 08, 2019 1:12 pm
aLeXXtoR Tue Jan 08, 2019 1:12 pm
daryl.dunlap wrote:For now, you'll have to manually transfer all attributes that you want to use in Shading to the Point Attribute level.
Easy, but what's next?
I can set color attribute to primitive or point whatever, but how should I use it as a color in the Octane Material?
Win 10 Pro 64bit | GeForce RTX 2070 SUPER 8Gb | AMD Ryzen 7 3700X | 32GB RAM
WebSite
Showreel
aLeXXtoR
Postby daryl.dunlap » Tue Jan 08, 2019 1:18 pm
daryl.dunlap Tue Jan 08, 2019 1:18 pm
According to the release notes, there are two new VOP nodes for Shading: Color Vertex Attribute and Float Vertex Attribute
daryl.dunlap
Postby aLeXXtoR » Tue Jan 08, 2019 5:17 pm
aLeXXtoR Tue Jan 08, 2019 5:17 pm
daryl.dunlap wrote:According to the release notes, there are two new VOP nodes for Shading: Color Vertex Attribute and Float Vertex Attribute
Is this about Octane 2019, or Octane 4?
Because I see no such nodes in Octane 4:
WebSite
Showreel
aLeXXtoR
Postby juanjgon » Wed Jan 09, 2019 11:35 am
juanjgon Wed Jan 09, 2019 11:35 am
This feature is available in the Octane 2018.1 plugins only:
viewtopic.php?f=102&t=70155
juanjgon
Postby aLeXXtoR » Wed Jan 09, 2019 1:39 pm
aLeXXtoR Wed Jan 09, 2019 1:39 pm
That is really sad since it's a core feature of Houdini.
WebSite
Showreel
aLeXXtoR
Postby deltarod » Fri Jan 11, 2019 10:21 am
deltarod Fri Jan 11, 2019 10:21 am
Did you find a solution alex?
deltarod
Postby aLeXXtoR » Fri Jan 11, 2019 10:26 am
aLeXXtoR Fri Jan 11, 2019 10:26 am
deltarod wrote:Did you find a solution alex?
I guess for geometry — baking colors to texture (or texture sequence) with Mantra and (after that) using it with Octane is the only option in v. 4.
Since I still haven't decided should I subscribe to 2018+ or look for alternatives, I don't see any other options.
WebSite
Showreel
aLeXXtoR
Postby aLeXXtoR » Sun Jan 13, 2019 11:55 am
aLeXXtoR Sun Jan 13, 2019 11:55 am
I also found this video as a solution: https://vimeo.com/172594655 by Rohan Dalvi
WebSite
Showreel
aLeXXtoR
Re: Attribute Workflow *FIXED
Postby daryl.dunlap » Fri Feb 01, 2019 3:21 am
daryl.dunlap Fri Feb 01, 2019 3:21 am
Fixed in 2018.3
daryl.dunlap
Previous
Return to Houdini
Users browsing this forum: No registered users and 19 guests
Fri Apr 26, 2024 8:14 am [ UTC ]
