Referencing a not available object
Forums: Referencing a not available object
Houdini Integrated Plugin
Postby tschwenke » Sun Dec 30, 2018 10:13 pm
tschwenke Sun Dec 30, 2018 10:13 pm
I have several alembic files with some points and use a "Copy to points" node to use a tube with these points. It looks good in the Houdini viewport, but the Octane IPR tells me that: The instance node "XXX" is referencing a not available object ""
Any workaround here?
Best wishes,
Thomas
http://www.thomas-schwenke.me
Houdini 18.5 || Win10 || i7 + 1 x RTX3080
tschwenke
Re: Referencing a not available object
Postby tschwenke » Sun Dec 30, 2018 10:16 pm
tschwenke Sun Dec 30, 2018 10:16 pm
Oh, "copy stamp" does the trick. Why is this? Doesn't the plugin support the "copy to points" node?
tschwenke
Postby juanjgon » Tue Jan 01, 2019 11:38 am
juanjgon Tue Jan 01, 2019 11:38 am
Hmm, I'm not sure what could be the problem. Can you please attach an example scene to try to reproduce this issue? Here it seems to work fine.
juanjgon
Postby tschwenke » Fri Jan 04, 2019 9:53 am
tschwenke Fri Jan 04, 2019 9:53 am
Thanks. Will create the scene and send it to you.
tschwenke
Postby tschwenke » Sat Jan 05, 2019 6:52 pm
tschwenke Sat Jan 05, 2019 6:52 pm
Here is the scene. I deleted all other parts. Hope it stills throws the error message :)
https://1drv.ms/u/s!Aj3rUlbEDZwyrDnS3XWmFcpDBvVz
Best wishes,
Thomas
tschwenke
Postby juanjgon » Wed Jan 09, 2019 12:36 pm
juanjgon Wed Jan 09, 2019 12:36 pm
The problem is that in this object some of the points have defined an "instance" point attribute with an empty string. Due to this attribute, the plugin thinks that this object is an instancer, but of course, it can't find the object to be instanced. To avoid this problem you need to delete this not used "instance" point attribute.
Hope it helps,
juanjgon
Postby tschwenke » Wed Jan 09, 2019 2:00 pm
tschwenke Wed Jan 09, 2019 2:00 pm
Oh, I see, thanks alot!
Best wishes,
Thomas
tschwenke
Return to Houdini
Users browsing this forum: No registered users and 23 guests
Sat Apr 27, 2024 4:01 am [ UTC ]
