OctaneRender™ 4 RC 6 -
Using the 'Batch Render Job' node in the above release with 'Save the denoised pass instead of the main beauty pass' option checked, I still get the main beauty pass written to disk.
funk wrote:This combination of sheen + coat + ior causes fireflies and reflection artifacts
funk wrote:Universal with metallic set to 1 has reflection artifacts not seen in the metallic material
EDIT: Universal clearcoat seems to be affected by this too
wallace wrote:They were basically floating point issues in implementation that caused some problems in some very specific cases
rodrsamuel wrote:hi! im having a problem on all octane 4 RC this problem persists on RC 6
i work with C4D Octane on large scenes arch viz projects and every time i enable out of core geo/textures i get cuda error 700 ilegal memory access
i have 7x evga ftw3 1080ti Hybrid with 2x evga 1600w power supply to have more than enough power on a ausus x99 e ws usb 3.1 motherboard.
msi on or off doesn't change anything, Gpu and Vram down clock doesnt do any diference. i have 64gb memory in my pc witch at least 50% is free with stock clock of 2133mhz
already unplugged GPUS one by one to check the hardware and the problem persists.
i dont know what else to try, lower parallel samples doesn't solve .
already used all drivers from 391.35
cheers
Return to Development Build Releases
