Hi, I use the script Ol' Ready Cam. I test with V4
it does not work !
I 'd like to use it with denoising to divide computing time
https://render.otoy.com/forum/viewtopic.php?f=73&t=41365
Thanks for your help
Jolbertoquini wrote:Hi Vijay and Dev Team,
I was trying OSL round edges and I get a error :
"<node 'OSL texture'>:98: error: Unsupported feature: trace()
<node 'OSL texture'>:99: error: unsupported signature for getmessage: only getmessage("baking", key, value) is supported, where key is a string literal.
trace()
function.coilbook wrote:Hi this was done in 3d. Anyway to have paint shader added to the Toon shader where we can set brush strokes ,edges, etc ? So it can look like this. Thanks
funk wrote:I noticed that if I enable the denoiser render passes, then select them, I get a GPU failure error. I dont have the denoiser enabled in cuda devices or the imager, but I dont think it should cause a failure.
Return to Development Build Releases
Users browsing this forum: No registered users and 19 guests
