Failed to load octane.dll
Forums: Failed to load octane.dll
A public forum for discussing and asking questions about the Octane for Unity Alpha
Moderator: ChrisHekman
Postby brolly234 » Wed Jun 06, 2018 1:20 pm
brolly234 Wed Jun 06, 2018 1:20 pm
Failed to load octane.dll (C:\Users\sandeep\AppData\Local\Octane\Unity\2018.1.0f2_1.1.1.1314_T1\octane.dll). Errorcode: 577
UnityEngine.Debug:LogError(Object)
Octane.DynamicLibrary:Load()
Octane.PluginDllLoader:LoadLibraries()
OctaneUnity.PluginController:Init()
OctaneUnity.PreferenceWindow:OnGUI()
UnityEngine.GUIUtility:ProcessEvent(Int32, IntPtr)
brolly234
Re: Failed to load octane.dll
Postby Xhed » Wed Jun 06, 2018 4:38 pm
Xhed Wed Jun 06, 2018 4:38 pm
Can you try upgrading to NVIDA CUDA Toolkit 9.2, that should fix the issue.
- Rick
Xhed
Postby brolly234 » Thu Jun 07, 2018 7:56 am
brolly234 Thu Jun 07, 2018 7:56 am
Xhed wrote:Can you try upgrading to NVIDA CUDA Toolkit 9.2, that should fix the issue.
I did but now i am getting error code 577 and 126
Failed to load OctaneUnity.dll (C:\Users\sandeep\AppData\Local\Octane\Unity\2018.1.0f2_1.1.1.1314_T1\OctaneUnity.dll). Errorcode: 126
brolly234
Postby Toridan » Thu Jun 07, 2018 12:33 pm
Toridan Thu Jun 07, 2018 12:33 pm
I had the error with ErrorCode: 126 when I updated to OctaneUnity 1.1.1.1341 and when I closed the Unity Project and opened again it disappeared.
Maybe this is your case too.
Best of luck!
Toridan
Postby Xhed » Thu Jun 07, 2018 12:36 pm
Xhed Thu Jun 07, 2018 12:36 pm
Could you verify that the dll has properly been installed to C:\Users\sandeep\AppData\Local\Octane\Unity\2018.1.0f2_1.1.1.1314_T1\, while I look into the issue? And could you also check which other files are present there? Does the issue persist after restarting Unity?
- Rick
Xhed
Postby brolly234 » Thu Jun 07, 2018 1:27 pm
brolly234 Thu Jun 07, 2018 1:27 pm
Xhed wrote:Could you verify that the dll has properly been installed to C:\Users\sandeep\AppData\Local\Octane\Unity\2018.1.0f2_1.1.1.1314_T1\, while I look into the issue? And could you also check which other files are present there? Does the issue persist after restarting Unity?
It persists even after restart. Files present are octane.dat,octane.dll, octaneunity.dll,libfxdsk.dl, cudnn64_7.dll, octaneunitypackage.
It used to work for me in previous version,problem started after updating to latest version
brolly234
Postby brolly234 » Sat Jun 09, 2018 11:43 am
brolly234 Sat Jun 09, 2018 11:43 am
Any work around for this problem??
brolly234
Postby ChrisHekman » Mon Jun 11, 2018 9:51 am
ChrisHekman Mon Jun 11, 2018 9:51 am
brolly234 wrote:Any work around for this problem??
577 - Damaged or improperly signed file/executable
127 - Means a dependency is missing
Both indicate something went wrong with an installation, or files are missing. The latest Octane version as new features that require the latest drivers.
- Remove the folder: C:\Users\sandeep\AppData\Local\Octane\Unity\2018.1.0f2_1.1.1.1314_T1\. (You will be promted by a reinstall when you open your OctaneUnity project)
- Re-install your nvidia drivers
ChrisHekman
Return to Octane for Unity
Users browsing this forum: No registered users and 22 guests
Sat Apr 27, 2024 11:12 pm [ UTC ]
