Octane Maya // Motion Blur using Velocity Attributes on .abc
Forums: Octane Maya // Motion Blur using Velocity Attributes on .abc
Moderator: JimStar
Postby alexito » Fri Apr 13, 2018 2:50 pm
alexito Fri Apr 13, 2018 2:50 pm
Hi
is "Motion Blur compute from Velocity Attributes working" ?
I don´t see any option in the Shape Attributes, I am looking for same feature as in the Octane Houdini plugin which has this option. This is the only way you can get Motion Blur when importing Alembics from Houdini for example.
Thanks a lot.
Alex
alexito
Re: Octane Maya // Motion Blur using Velocity Attributes on .abc
Postby calus » Sat Apr 14, 2018 10:38 am
calus Sat Apr 14, 2018 10:38 am
alexito wrote:Hi
Thanks a lot.
Alex
yes you need to disable "constant topology" in 3.07 plugin (version 11.11 and previous ).
in the new beta 3.8 plugin ( from version 12.9 ) the velocity vertex map is automatically used for motion-blur and you can adjust the strongness with "max MV displace".
Also don't forget to tell Maya which color set is used for Motion Vector :
Pascal ANDRE
calus
Postby alexito » Mon Apr 16, 2018 10:28 am
alexito Mon Apr 16, 2018 10:28 am
Thanks Pascal , will give it a try now.
Best
Alex
alexito
Return to Autodesk Maya
Users browsing this forum: No registered users and 16 guests
Sat Apr 27, 2024 9:17 am [ UTC ]
