Help with falloff node. What am I missing.
Forums: Help with falloff node. What am I missing.
Postby gordonrobb » Fri Mar 23, 2018 12:00 pm
gordonrobb Fri Mar 23, 2018 12:00 pm
Doing a bit of testing, trying to get a good see through plastic. I am wanting to use the falloff node to control the scattering.
here is my node setup....
I have a white texture and a black texture through a mix node. With the mix at zero percent. This is what it looks like
At 100%, it looks like this.....
So I want to control this with a fall off. Which I have set to min 0 and max 1. But when I plug this into the mix, I get this...
What they hell am I doing wrong?
gordonrobb
Re: Help with falloff node. What am I missing.
Postby baltort » Fri Mar 23, 2018 12:04 pm
baltort Fri Mar 23, 2018 12:04 pm
What are your settings in the falloff node?
Cheers,
J.
baltort
Postby gordonrobb » Fri Mar 23, 2018 12:29 pm
gordonrobb Fri Mar 23, 2018 12:29 pm
just the defaults. 1,0 and 6 (although I want it to be 10). there is a massive increase in how bright the surface is. Surely 1, should equate 100% mix, which should mean that part should just look like the surface does in the 100% image.
gordonrobb
Postby juanjgon » Sat Mar 24, 2018 5:46 pm
juanjgon Sat Mar 24, 2018 5:46 pm
I'm not sure what could be the problem. If you want to share the scene, I could take a look at it here.
juanjgon
Postby gordonrobb » Sun Mar 25, 2018 3:51 pm
gordonrobb Sun Mar 25, 2018 3:51 pm
I’ll package it up when I get home. How do I send it to you? :)
gordonrobb
Postby juanjgon » Sun Mar 25, 2018 7:36 pm
juanjgon Sun Mar 25, 2018 7:36 pm
gordonrobb wrote:I’ll package it up when I get home. How do I send it to you? :)
You can attach it to a pm, or use my email [email protected]
juanjgon
Postby gordonrobb » Mon Mar 26, 2018 8:42 am
gordonrobb Mon Mar 26, 2018 8:42 am
I have sent you the file. Let me know what I'm doing wrong :)
gordonrobb
Postby juanjgon » Mon Mar 26, 2018 11:39 pm
juanjgon Mon Mar 26, 2018 11:39 pm
Thanks, I've reported this issue to the Octane devs, because it sounds like a core issue to me.
juanjgon
Postby gordonrobb » Tue Mar 27, 2018 8:34 am
gordonrobb Tue Mar 27, 2018 8:34 am
OK, thanks. So am I right in my assumption that this should allow me to blend between the two? And I wasn’t doing anything wrong?
gordonrobb
Postby juanjgon » Tue Mar 27, 2018 9:52 am
juanjgon Tue Mar 27, 2018 9:52 am
Yes, this is what I understand. To me, it seems some kind of issue on the Octane side with this shader setup.
juanjgon
Next
Return to Lightwave 3D
Users browsing this forum: No registered users and 31 guests
Sat Apr 27, 2024 10:15 pm [ UTC ]
