Octane on iMac - Radeon Pro Videocard
Forums: Octane on iMac - Radeon Pro Videocard
Postby ivosj » Tue Jan 30, 2018 3:18 pm
ivosj Tue Jan 30, 2018 3:18 pm
Hallo,
I'm trying to run Octane demo version on iMac :
(Retina 5K, 27-inch, 2017)
- mac OS High Sierra (10.13.2)
- processor: 4,2 Ghz Intel Core i7
- 32 GB 2400 MHz DDR4
- Radeon Pro 575 4GB
As with some others even after installing CUDA 9.1.128 and CUDA driver 387.128 it still reports No CUDA GPUs.
Thank you for your help.
Ivo
ivosj
Re: Octane on iMac - Radeon Pro Videocard
Postby bepeg4d » Tue Jan 30, 2018 3:34 pm
bepeg4d Tue Jan 30, 2018 3:34 pm
Hi Ivo,
unfortunately, CUDA can be used only with Nvidia GPUs, so installing it with an AMD GPU does not help.
You need an external eGPU solution via Thunderbolt with Nvidia GPU inside, to be able to use OctaneRender on your iMac:
viewtopic.php?f=30&t=62409
viewtopic.php?f=9&t=43439&start=170#p276341
ciao beppe
Postby ivosj » Thu Feb 08, 2018 8:24 pm
ivosj Thu Feb 08, 2018 8:24 pm
Hallo beppe,
thank you for your reply. I was considering getting Akitio Node in combination with Nvidia GTX 1080Ti so that I could use it also with a combination with my windows laptop Dell XPS 15 9550.
What are the experiences of using eGPU with a windows machine + Octane render?
Thank you
Ivo
ivosj
Postby bepeg4d » Fri Feb 09, 2018 9:08 am
bepeg4d Fri Feb 09, 2018 9:08 am
Hi Ivo,
sorry, I have no experience with eGPU under windows, but it should be straight forward, I guess.
ciao beppe
Postby frankmci » Fri Feb 09, 2018 5:44 pm
frankmci Fri Feb 09, 2018 5:44 pm
ivosj wrote: I was considering getting Akitio Node in combination with Nvidia GTX 1080Ti so that I could use it also with a combination with my windows laptop Dell XPS 15 9550.
We've been using that combo on our Mac Pros since last Spring without much trouble. The website egpu.io has lots of useful information and a nicely supportive forum that should help you on your way.
- Frank
Technical Director - C4D, Maya, AE, - Washington DC
frankmci
Postby vento33 » Tue Apr 17, 2018 2:06 pm
vento33 Tue Apr 17, 2018 2:06 pm
hi there Guys!
i've been following up this post for a while to find assistance for running Ocatne on MAC!
i need help.
i have an IMAC late 2015 so i guess is with thunderbolt 2.
i know i need an external GPU, but im overwhelmed with too many options that im lost here!
so if someone knows.
what GPU box works for my late 2015 imac, what specific graphic card i should put over there.
if someone can help me with some tips that i would appreciate a lot :)
thanks
vento33
Postby bepeg4d » Wed Apr 18, 2018 8:53 am
bepeg4d Wed Apr 18, 2018 8:53 am
about eGPU boxes:
https://www.sonnettech.com/product/egfx ... y-box.html
Apple adapter TB3/USB-C to TB2:
https://www.apple.com/shop/product/MMEL ... -2-adapter
About GPUs, my suggestion is GTX 1070/1070ti/1080ti:
https://render.otoy.com/octanebench/res ... ingleGPU=1
At the moment, installing under Sierra is much more easy:
While under High Sierra better to stay with 10.13.3, and wait for the new script for 10.13.4:
https://egpu.io/forums/mac-setup/wip-nv ... gh-sierra/
Happy Mac eGPU Rendering,
ciao Beppe
Postby pietervonk » Sat Oct 27, 2018 2:36 pm
pietervonk Sat Oct 27, 2018 2:36 pm
bepeg4d wrote:Hi,
about eGPU boxes:
ciao Beppe
Hi Beppe,
Are you sure the thunderbolt adapter: Thunderbolt 3 (USB-C) to Thunderbolt 2 Adapter is good when you want to run the thunderbolt eGPU?
Thanks, Pieter
pietervonk
Postby bepeg4d » Mon Oct 29, 2018 2:53 pm
bepeg4d Mon Oct 29, 2018 2:53 pm
yes, it works, but avoid to connect a monitor to the eGPU, and use it only for Octane rendering.
ciao Beppe
Postby frankmci » Tue Oct 30, 2018 8:44 pm
frankmci Tue Oct 30, 2018 8:44 pm
pietervonk wrote:
Hi Beppe,
Thanks, Pieter
I can second Beppe. The Thunderbolt 2 to 3 (USB-C) adapter works fine for sending render data back and forth, but you don't want to try to push live screen video across that cable at the same time; it will be very unhappy. I think this is why Apple chose to disable this functionality (eGPU via TB 2) out of the box on High Sierra, so that people wouldn't complain that it's broken. Fortunately the innards of Mac OS are accessible enough to let us go in and re-enable it, and it's plenty of bandwidth for non-realtime 3D graphics rendering.
frankmci
Return to Demo Version Questions & Discussion
Users browsing this forum: No registered users and 15 guests
Sat Apr 27, 2024 2:53 am [ UTC ]
