Blending two multi/sub material with octane mix material
Forums: Blending two multi/sub material with octane mix material
Please post only in English in this subforum. For alternate language discussion please go here viewforum.php?f=18
Postby coilbook » Tue Jul 05, 2016 5:01 pm
coilbook Tue Jul 05, 2016 5:01 pm
I have an object that has 10 materials and they are all inside Multi/Sub object material.
Goal is to mix using Octane Mix material : Multi/Sub object material in material 1 and some other material in material 2 and use amount. But when I add Multi/Sub object material. to material one my objects turns grey. Any idea Thanks
coilbook
Re: Blending two multi/sub material with octane mix material
Postby azen » Fri Jul 08, 2016 3:37 am
azen Fri Jul 08, 2016 3:37 am
The mix material can't take in the multi/sub object as a material - an Octane Mix Material only accepts other Octane Material Types. Multi/Sub Objects. Could you provide some more details about the look you want to achieve? The look you want to achieve should be possible using a combination of Mix Materials.
azen
Postby coilbook » Fri Jul 08, 2016 7:37 pm
coilbook Fri Jul 08, 2016 7:37 pm
We were trying to make pain washing effect. Where one paint color disappears and original object colors appear. We fixed it by applying each mix material to each material. I wish octane will support multi sub and mix one day
coilbook
Postby azen » Tue Jul 12, 2016 3:21 am
azen Tue Jul 12, 2016 3:21 am
coilbook wrote:We were trying to make pain washing effect. Where one paint color disappears and original object colors appear. We fixed it by applying each mix material to each material. I wish octane will support multi sub and mix one day
That would be nice feature to have, though it would be difficult (if not impossible) to implement a clean integration between multi-sub objects (a 3ds Max node) and mix materials (which only takes in other Octane material nodes). Maybe an investigation into viable workarounds would turn up something fruitful, but the time and effort needed for such an undertaking is currently infeasible. Apologies for the inconvenience.
azen
Postby coilbook » Fri Jun 23, 2017 11:05 pm
coilbook Fri Jun 23, 2017 11:05 pm
hi Any news on using multi object material and octane mix material
coilbook
Postby paride4331 » Thu Jun 29, 2017 10:48 am
paride4331 Thu Jun 29, 2017 10:48 am
Hi coilbook,
In some situations, you could be able to solve mixing the materials before using in imulti/sub with previous IDs.
paride4331
Postby coilbook » Thu Jun 29, 2017 1:38 pm
coilbook Thu Jun 29, 2017 1:38 pm
Thank you
coilbook
Return to Autodesk 3Ds Max
Users browsing this forum: No registered users and 19 guests
Sun Apr 28, 2024 4:19 am [ UTC ]
